Hi Gents
I have a 2.7i IFS shape, it starts, runs on 4 cylinders for a second and then dies.
Any thoughts??
2.7 IFS Starts then cuts out
- Dowe Koos
- Real Name: Hennie
Re: 2.7 IFS Starts then cuts out
Sien viewtopic.php?f=3&t=39886 mag jou help
- Tarquin
- Town: Plettenberg Bay
- Real Name: Tarquin
Thanks for the info. im not sure if its the same problem tho.. i will try roll start and see what happens
- Tarquin
i tried to pull start, it still doesn't want to run
If it did not start the first time, they tend to flood after more attempts.
What mine did just after I bought (7 years ago) it was exactly what you described, start, run one second, die.
I learned to keep my foot far away from the accelerator pedal when starting it, because once you flooded it you won't get it going that same day, try again tomorrow. Or replace the spark plugs and then try again.
also check the idle control valve, see
viewtopic.php?p=439777#p439777
- Big D
- Vehicle: SFA Hilux 2.2 BFi
- Real Name: Deon
Need a bit more info...
Does it happen when the engine is cold / hot/ any time? Random?
When did this start? After a service? replacement of parts?
Any alarm / immobilizers?
- Tarquin
vehicle is standard, just started all of a sudden. no service or parts replaced at the time.Big D wrote:Need a bit more info...
has the standard toyota imobilizer
i think its the immobilizer, but was hoping to hear if someone has something similar
Pieter what did you do to remidy your problem? i don't think an efi vehicle can flood. it does start and runs perfectly and then just dies.
- Town: Springs
- Vehicle: Hilux 2700i
- Club VHF Licence: HC262
Override the mobilizer with your remote and see what happens.I think the plug is in the fuse box.
