Advice needed on SFA 2.2 EFI
- Bosfebok
- Town: Roodekrans
- Real Name: Otto
- Club VHF Licence: X248
Hi fellow Luxers
I need some help. Couple of years ago I went EFI, but with a turbo as well. I want to take the vehicle back to just an EFI because it is extremely heavy on juice.
The current EFI is a Gotech MFI-X system that is firing the injectors in batch mode (0) (all firing at the same time).
So the question is :
- Is this the right mode for a normal EFI conversion?
- Does the batch mode not make your car very heavy on juice...as I can tell you, my 2.2 is now a guzzler.
- If not Mode 0, then which mode?
- Do I need to get anything extra to be able to fire the injector individually and at the right time and sequence?
I have a Toyota EFI intake.
Anyone you can recommend on the West Rand to assist me?
Many thanks.
Otto
Many thanks.
Otto
Otto X248
20.5" LED BAR
Nudge-M front bumper
80l Long Range Fuel Tank
90l Water Tank
Slide Drawer System
Safari Snorkel
Diff breathers
20.5" LED BAR
90l Water Tank
Slide Drawer System
Safari Snorkel
Diff breathers
- Borntofish
- Vehicle: Hilux 86
- Real Name: Werner
Re: Advice needed on SFA 2.2 EFI
Think you need to speak to Louis Zanoli on this forum. Member name 4x4Megaworld.
- Stef
- Vehicle: '98 LTD
- Real Name: Stefan
- Club VHF Licence: X107
As far as I know the Dictator also does batch firing... 2 injectors at a time which is what I'm running.
If possible go sequential although I doubt if that would have a significant effect on consumption.
- Vlak vark
- Town: Phalaborwa
- Real Name: Nico
Hi Otto,did you look at dictator management?
- Club VHF Licence: X93-
Borntofish wrote:Think you need to speak to Louis Zanoli on this forum. Member name 4x4Megaworld.
+1 Louis did my EFI conversion on my SFA.He will sort out your problem very quickly
- Bosfebok
- Town: Roodekrans
- Real Name: Otto
Thanks gents, will give him a call.
Otto X248
20.5" LED BAR
90l Water Tank
Slide Drawer System
Safari Snorkel
Diff breathers
20.5" LED BAR
90l Water Tank
Slide Drawer System
Safari Snorkel
Diff breathers
Hi, batch firing is correct. You won't win anything with sequential injector firing. Sequential firing would require a much more accurate timing method like a crank timing sensor. The magnetic distributor based timing won't do.
IMHO, it's the turbo that's making it guzzle fuel!
- Stef
- Vehicle: '98 LTD
- Real Name: Stefan
I would rather go with Spitronics; can get far more accurate with the tuning. If I have money to burn I would swap out the Dictator in my current setupVlak vark wrote:Hi Otto,did you look at dictator management?
I agree Stef, At this moment in time Spitronics is the more versatile ECU. However, it all rides on how that ECU is mapped, and that is the critical factor with all the different brands. Get the right guy to set it up and it could mean the difference between chalk and cheese.
- Bosfebok
- Town: Roodekrans
- Real Name: Otto
Thanks gents, I have made contact with Louis.
Otto X248
20.5" LED BAR
90l Water Tank
Slide Drawer System
Safari Snorkel
Diff breathers
20.5" LED BAR
90l Water Tank
Slide Drawer System
Safari Snorkel
Diff breathers
- Stef
- Vehicle: '98 LTD
- Real Name: Stefan
True...mine was done by Schalk so I'm sure it's as good as it can be, but the man himself said the rpm increments are finer on the Spitronics. I'm sure that if Dicktator decide to change the firmware to accommodate the same then for the EFi conversion on our 22R's it would be just as good.Mud Dog wrote:I agree Stef, At this moment in time Spitronics is the more versatile ECU. However, it all rides on how that ECU is mapped, and that is the critical factor with all the different brands. Get the right guy to set it up and it could mean the difference between chalk and cheese.
