3rz Spitronics with 3ct turbo
- Chris Jordaan
- Town: Oudtshoorn
- Vehicle: 1993 4x4 Hilux
- Real Name: Christo
Will the 3ct turbo be enough for low boost on the 3rz. On simular forums a significant gain in torque can be gained by adding an low boost turbo or supercharger to a standard 3rz engine. No added fuel consumption to be gained as long as long as u dont add weight to your right foot due to an adrenilen rush to the head. Is there somebody that has done this and what was your success or losses
Re: 3rz Spitronics with 3ct turbo
I'm sure it's all been done before but can't recall anyone here having done it. The 3RZ is a notoriously tough and reliable motor, so I assume that for the best part it should be able to handle it and with the correct re-mapping should give significantly more power and thus better fuel consumption, if as you say you keep control of your right foot.
One thing bothers me a bit and it's common to most motors today - they're built so compact that the amount of meat between the cylinders is very small, and with the higher compression achieved and this already being a weak point in the gasket might tend to blow with standard gaskets.
I would personally be more inclined to go the route of supercharger rather than turbo, and as you say, keep the 'boost' on the lower side.
- Chris Jordaan
- Town: Oudtshoorn
Need as little as 5psi boost. Have a 3ct already in my bakkie that went. Difficult to get spares for it so i can use its turbo.
