Steering wheel replacement
Posted: Wed Mar 08, 2017 12:16 pm
by dalkill
my bakkie steering wheel is bit run down... it's starting to peel, and leaves little bits on hands as i'm driving.
I thought of getting another on at scrap yard... what can i expect to pay?
will the later vigo shapes 2011+ also fit and not interfere with my airbag?
could i replace it myself or do i have to take it to stealers?
any hidden issue with trying to remove airbag? or is it just few screws and that it?
Re: Steering wheel replacement
Posted: Fri Mar 10, 2017 1:09 pm
by Hilux 1
Shaakir, get hold of OMO(Louis) he works for the stealers and will be able to help.
Posted: Mon Mar 13, 2017 9:13 am
by dalkill
thanks, will do
Posted: Mon Mar 13, 2017 12:56 pm
by Die$eL
i also want to replace or just dye mine. the wheel is in good shape. just that the colour is wearing.
any ideas about where to get a dye?
Posted: Mon Mar 13, 2017 1:17 pm
by dalkill
mine is the standard rubber kind.. no leather. rubber just busy rubbing of on my hand. has become bit brittle from sun exposure.
could one have it covered in leather? Any recommendations in CT? it might be a bit thick though?
Posted: Mon Mar 13, 2017 3:17 pm
by Scott
Midas does nice covers had the same on my Isuzu.
Posted: Thu May 25, 2017 5:07 am
by JAMES399
Die$eL wrote: ↑Mon Mar 13, 2017 12:56 pm
I refinished the dash, door panels and steering wheel on my wife's Isuzu Trooper, as well as the door panels on my 2003 Hilux. Factory look, and so far very durable. I used SEM Products COLOR COAT in spray cans to do it.
https://www.semproducts.com/aerospace-r ... m-aerosols
Good Luck.
- JAMES
Posted: Wed May 31, 2017 8:30 am
by Die$eL
JAMES399 wrote: ↑Thu May 25, 2017 5:07 am
Good Luck.
- JAMES
You sir are a legend! This is exactly what I've been looking for.
Now, how do i figure out what colour i need...
Also, where did you buy it? Did you use the primer etc. or just the classic coat?
