Toyota Avanza - fuel filter replacement
Of course there are people who only dream about driving a Hilux or Cruiser. They are welcome to show us their current vehicles here, ask questions or post some exciting new releases.
louis fourie
Club VHF Licence: X101
Thu Oct 12, 2017 4:07 am
Not a Hilux, but still a Toyota.
The fuelpump of the Avanza with the fuel filter is as far as I could get in the fuel tank itself. Is there an inspection hole through the floor or must one drop the fuel tank?
Sent from my HUAWEI VNS-L31 using Tapatalk
Polarbear2008
Real Name: Theunis
Club VHF Licence: X49
Thu Oct 12, 2017 6:19 am
Hi Louis. I bit of searching led me to the answer you did not want to hear. It seems the tank would have to come out. See here: http://www.answers.com/Q/How_to_replace ... ota_avanza
Sent from my SM-G925F using Tapatalk
Monroe Gas Magnum shocks
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
louis fourie
Thu Oct 12, 2017 8:49 am
I' ve seen that one, but refuse to believe it
Thu Oct 12, 2017 9:26 am
It is very strange for me that Toyota would install a service item inside the petrol tank in such a manner that the tank needs to be dropped in order for it to be replaced. Normally there would be a strainer of some sorts in the petrol tank that would keep the biggest particles out of the pump. There has to be another petrol filter somewhere. Follow the fuel line from the engine to the tank and see if there is one in line. I suspect that may be the case.
Die$eL
Town: Midrand
Real Name: Nishan
Thu Oct 12, 2017 10:51 am
usually on a Toyota you would remove the rear seat and can then access the fuel filter and pump. The Avanza should be the same
Real drivers use three pedals
Thu Oct 12, 2017 11:14 am
There should be an inspection cover in the floor above the tank. :winkx:
louis fourie
Thu Oct 12, 2017 6:28 pm
Mud Dog wrote:There should be an inspection cover in the floor above the tank. :winkx:
I hope so uncle Andy. Bl...... Fuelfilter cost R1600
Thu Oct 12, 2017 6:34 pm
:blink: :blink:
Geez!
Return to “Other Vehicles”
