Rough idle 2012 3.0 D4D auto
T Dog
Town: Winchester
Vehicle: 2012 Hilux 3.0 D4D auto
Real Name: Terence
Post by T Dog »
Hi guys. We moved to the UK 3 years ago and after a rough ride in a MazdaCX 5, I’m back in my beloved Hilux. I have the 3.0 auto D4D which I look forward to getting into each day except for:
When she’s warm, she experiences rough idle when in drive or reverse. This is to say, when I arrive at a robot and stop, the engine idles irregularly like it is on the verge of stalling( it never does stall). If I slip it into neutral she returns to normal idle. She drives beautifully. Fuel consumption seems normal and other than the rough idle under load, I can’t fault her.
The following has been replaced:
Egr valve
Engine coolant temperature sensor
Maf sensor
Diaphram filter on map sensor
Throttle body
There are no apparent air leaks on the intake side. The fuel injectors have been removed and tested by Bosch approved workshop and all ok. It’s such and insignificant issue but a huge irritation.
Any thoughts or suggestions?
Baksteen87
Vehicle: 2001 3.0 Toyota Hilux KZ-TE
Real Name: Winton
Re: Rough idle 2012 3.0 D4D auto
Post by Baksteen87 »
Hi Terence
Had a similar problem with idling and a few others but after cleaning my valve timing sensor on the diesel pump all my problems was sorted also had n diesel knock which was sorted after cleaning the plug
dalkill
Town: Cape TOwn
Vehicle: 2.4 GD6 SR D/C 4x4
Real Name: Shaakir
Post by dalkill »
Baksteen87 wrote: Wed May 20, 2020 9:02 pm valve timing sensor on the diesel pump
is that something different to the suction control valve?
I had my SCV replaced after machie plugged in laptop and saw some variances in the pressure or something like that.
No rough idling though. Just a precautionary thing.
TOYOTA IS MY LEWE
dalkill
Town: Cape TOwn
Real Name: Shaakir
Post by dalkill »
T Dog wrote: Sat Apr 11, 2020 9:40 am If I slip it into neutral she returns to normal idle.
so from this I'm assuming it has something to do with auto box.
maybe the gearbox oils (is it some sort of viscous oils i'm geussing) that not good anymore and when heats up... it's trying to exgange the clutch :?:
TOYOTA IS MY LEWE
Return to “Open Discussion”
