hi all
1995 single cab hilux raider 22R engine
Mostly the starter motor works just fine.
Intermittently I will turn the key and there is a click, the dash lights dim, but no crank.
Ask the wife to help, then while she is turning the key, I tap the starter motor with a small hammer and there she goes - it cranks and fires.
Or if it is possible to move the car just a bit, while turning the key and just a touch of clutch, the starter will crank.
Now either of these methods is not ideal at a lion sighting in the Kgalagadi, is it?
I have the starter motor out now, is this something I can fix or where do I take it to be fixed, or must it be replaced?
22R starter motor needs help
- Vehicle: 1995 2.4 hilux
- Real Name: Geoff
- Tim86
- Real Name: Tim
Re: 22R starter motor needs help
Hi Geoff
I had the same scenario. The power for the solenoid runs through the key barrel, and the contacts in the barrel wear out and don't allow enough current through to enable the solenoid to function properly, hence the click sound. The tap of the hammer jiggles the solenoid and bendix just enough to let the bendix slide into the fully engaged position with the flywheel teeth. Instead of trying to fit a new barrel, install a relay that runs off the ignition key wires and connects good power straight from the battery to the solenoid.
- Town: Harkerville WC
- Vehicle: 1990 Hilux 4Y
- Real Name: Peter
Hi Tim, I respectfully disagree with you. While possible that it is the ignition, the more likely cause is worn or pitted contacts on the solenoid itself. The banging on the starter allows contact and it starts. This is a common problem on old starters and is really easy to fix by opening and cleaning the contacts and side walls. At the worst, rebuild kits are readily and cheaply available at Midas type outlets. Geoff, try this 1st, the most difficult part is taking the starter out, the rest is easy, peasy.
- Tim86
- Real Name: Tim
Sure thing, merely my experience with the problem I had, however, the solenoid seems to more commonly be the problem.
A link to my thread on it:
viewtopic.php?f=3&t=43838
Geoff if you need a replacement solenoid I have one brand new in the box.
- niclemaitre
- Town: Stellenbosch
- Vehicle: 99 IFS DC 4x4
- Real Name: Nic
I'm going with the starter solenoid is dying. The ignition should be via a relay as stock surely?
Happy trails
Nic
SFA '87 DC "Rooies" - sold
IFS '99 DC "Benny"
Nic
IFS '99 DC "Benny"
- Hilux 1
- Real Name: Tertius
- Club VHF Licence: HC137
you can alway contact Cliffie Hesterman at Condiesel in Epping for some advice. otherwise try Ivan at ICM autoparts, both very Knowledgable
