The front driveshaft ( the one between the transfer case and the front differential) in my '03 Hilux 4x4 clunks like crazy when the truck is in 4wd. I removed it, and the 3 ujoints in it are toast. I took it to my mechanic and he said the entire driveshaft must be replaced. Tried other mechanics and got the same response. Here's what the shaft looks like:
The cv joint is in the "H" yoke. It consists of a ball and a rod separated by a spring. The spring in my truck is broken off. Buying a complete new driveshaft costs over $700 dollars, and I've not found one available anywhere. I have a set of replacement u-joints. Do you guys know of a replacement CV joint kit ?? Or ... should I just install the new u-joints and go for it?? I seldom use 4wd. Only to get through deep mud or up steep hills. Never over 5 mph.
Opinions ???
James
2003 Hilux 4x4 front driveshaft CV joint repair kit.
- niclemaitre
- Town: Stellenbosch
- Vehicle: 99 IFS DC 4x4
- Real Name: Nic
Re: 2003 Hilux 4x4 front driveshaft CV joint repair kit.
Didn't you ask this exact question the other day?
Anyway, you can replace the U-joints, I just had it done on my front prop, from the same era IFS Hilux, where they replaced all three U-joints.
Happy trails
Nic
SFA '87 DC "Rooies" - sold
IFS '99 DC "Benny"
Nic
IFS '99 DC "Benny"
- Town: Alejandria Antioquia Colombia SA
- Vehicle: Toyota Hilux 4x4
- Real Name: JAMES
Maybe I did. Lo Siento. I posted it on several sites. I guess I lost track.niclemaitre wrote: ↑Wed Jun 14, 2023 9:37 am Didn't you ask this exact question the other day?
UPDATE:
I purchased the three replacement U-joints, and used my shop press to install them. I found that the spring that holds the ball for the CV joint under pressure had fractured, and this was causing the clunking noise.I looked through my parts drawers, and found a suitable replacement spring.Then, I drilled a small hole in the side of the CV joint, tapped it, and installed a zerk fitting. Pumped the CV joint full of a light silicone grease. Now the front driveshaft is as good as new ... Well almost anyway. The clunking noise is gone, and the driveline binding that was there when the truck was in 4wd has disappeared. Total cost for parts $390 mil Colombian Pesos (about $100 USD). A far cry from the $700 USD+ that the mechanics wanted.
- JAMES
BTW, Senor NICLEMAITRE -
Thanks for your reply and help. - J.
