Rear diff strip
Introduce yourself and Meet the rest of the crowd
meob
Town: Upington
Real Name: Gert
Rear diff strip
Post by meob »
Hi I am new to this forum.
I have a build up hilux with hilux single cap body but KZte double cab 4x4 undercarriage.
the engine is a chev 383 stroker v8.
I went on a namib desert dune drive trip and on the first day stripped the crown wheel and the pinion.
the load was heavy and I think the main reason for strip. I had to complete the trip with only front wheel drive and was a huge challenge, but with the help of the guide I made it through to Walvisbay.
the ratio is 3.27. 41 and 11 teeth gears.
do you suggest I stay with ratio or do I change it and where can I find the replacement gears or diff.
thanks and see you guys soon in the Namib desert.
Re: Rear diff strip
Hi Gert and welcome! :thumbup:
I'm open to correction, but that sounds like it's the KZ (diesel) diff ratio. Diesels have plenty torque but not the rev range of a petrol motor, which is why they use the longer ratio, but the V8 should have enough guts and is also not a high revving motor, so I would leave it as is - also, it will give you longer legs on the open road. The only downfall is that the diff will strain a little more and as you say, the heavy load along with the V8 power is more than likely the cause for having stripped it. Another reason why I would keep the same ratio is that if you change the back, you also have to change the front and that can become a pricey exercise without really gaining much. If it were a competition vehicle, then yes, it would be justified, but not for an overlander.
You might be able to get a second hand or reconditioned unit, just visit your local diff / gearbox centre. You could even try scrapyards, but there's no guarantee and you never really know the condition of the unit, so this should be a last resort for reliability on long distance travelling.
Hope you get sorted. :winkx:
meob
Town: Upington
Real Name: Gert
Re: Rear diff strip
Post by meob »
thanks mud dog. i will rather then repair with toyota parts. they gave me a quote and not that bad.
Re: Rear diff strip
Best option! :thumbup:
louis fourie
Club VHF Licence: X101
Re: RE: Re: Rear diff strip
Post by louis fourie »
meob wrote:thanks mud dog. i will rather then repair with toyota parts. they gave me a quote and not that bad.
Hallo Gert en welkom
Wat het Toyota jou ge-quote?
meob
Town: Upington
Real Name: Gert
Re: Rear diff strip
Post by meob »
ek koop parte by toyota vir so R7500 en dan beteel ek werktuigkundige nog n R1000 werk te doen
Return to “Meet the People”
