Wheel locks
- Theodorus
- Town: Honeydew Jhb
- Vehicle: HILUX
- Real Name: Theo
Wheel locks
Hi can i get some info when i want to lock my front wheels the driver side is very hard to turn the knob need some advice on how to fix it and how does it work please
Re: Wheel locks
It can either be that the grease on the inside is hard or that there is hard grease between the moving part and solid part.
The quick solution can be to spray it with Q20 on the outside in the space between the moving (knob) and solid part.
The correct solution is to remove the cover (take those 6 bolts out) then clean it, put new grease and put back in. There is not much that can go wrong, after you removed the lid just note the position of all the parts.
Re: Wheel locks
Are you maybe a commentator by trade? Juts wondering because you didn't take any breaths in that long sentenceTheodorus wrote:Hi can i get some info when i want to lock my front wheels the driver side is very hard to turn the knob need some advice on how to fix it and how does it work please
I would rather just take off the cover and clean it out and put in new grease. Just be very careful when tightening those cover bolts as they only need to be torqued to 9NM if I remember correctly and strips quite easily
- Theodorus
- Vehicle: HILUX
- Real Name: Theo
Wheel locks
Thank you , ha ha what grease should i use
Mylux
Mylux
Re: Wheel locks
Mine did not strip but I turned off the head of the bolt, so i replaced them with stainless boltsI remember correctly and strips quite easily
But yes, dont over tighten them
Re: Wheel locks
That is what I meant... the head comes of quite easily....pietpetoors wrote:Mine did not strip but I turned off the head of the bolt, so i replaced them with stainless boltsI remember correctly and strips quite easily
Will get back to you on the type of grease
Re: Wheel locks
You can check this manual... page 29 onwards.... http://www.hilux4x4.co.za/manual/2_4Hil ... ENSION.pdf" onclick="window.open(this.href);return false;
And it's MP grease you need to use
- Club VHF Licence: X93-
Re: Wheel locks
10NM as per gregorys workshop manualCasKru wrote:Are you maybe a commentator by trade? Juts wondering because you didn't take any breaths in that long sentenceTheodorus wrote:Hi can i get some info when i want to lock my front wheels the driver side is very hard to turn the knob need some advice on how to fix it and how does it work please
- george
- Town: Velddrif
- Vehicle: Triton 3.5l V6
- Club VHF Licence: HC107
Re: Wheel locks
i am not to sure if the spring comes out when you take off the cover. if it does than make sure the spring is insert correctly. My hub was buggered up because a previous mechanic had insert the spring incorrectly.
Re: Wheel locks
Best is to remove cover when in unlocked position , then spring should not come out and you can check properly where everything is. If you turn the knob to lock position the spring will pop out.
Re: Wheel locks
Ewe / yebo.pietpetoors wrote:Best is to remove cover when in unlocked position , then spring should not come out and you can check properly where everything is. If you turn the knob to lock position the spring will pop out.
- Theodorus
- Vehicle: HILUX
- Real Name: Theo
Wheel locks
Dankie maters gaan dit oor die nawaak doen hoop julle het n goeie jaar voorentoe
Mylux
Mylux
- Vehicle: 2002 face lift KZ-TE DC. Mod’s / dual batter - kinda ;) / Active suspension / Intercooler / free flow / ECU Chip / sports flow air filter
- Real Name: Martin
Re: Wheel locks
Ek't 'n similar issue gehaad.
hier is 'n manual step by step guide.
Maar ek't marine grease gevat.
Is so 2 ure se werk
Is so 2 ure se werk
One Africa, One Hilux needed :)
