FORTUNER VIBRATES (ON THE PASSENGER SIDE) BEYOND 110 KM/H
- Alex2539
- Town: Walvis Bay
- Vehicle: HILUX LEGEND 45 V6 4.0 4X4
- Real Name: Alex
Hi there
Perhaps other fortuner drivers have experienced this. We have an 06 model Tuna, once the speed goes beyond 110 km/h i can feel it vibrating on the passenger side (also visible by observing the side mirror). Last year the dealer said it was the propshaft, they balanced it and replaced the joints. The vibration never disappeared, we changed shocks, balanced the wheels etc to no effect. We are currently using general grabbers. Mileage: 229000km
any advice?
any advice?
Bonded to Yotas
- WayneSchalk
- Town: Krugersdorp
- Real Name: Wayne
- Club VHF Licence: X117
Re: FORTUNER VIBRATES (ON THE PASSENGER SIDE) BEYOND 110 KM/H
Did balancing and new shocks make any difference at all?
I assume yours is the 4x4 right?
- jvt172
- Vehicle: Hilux 3.0d4d 4x4
- Real Name: Jurgen
Mine also doing it. 2014 model 95000km on the clock
- Alex2539
- Town: Walvis Bay
- Real Name: Alex
Minor improvement. it is a 4x4 yesWayneSchalk wrote:Did balancing and new shocks make any difference at all?
Bonded to Yotas
- Alex2539
- Town: Walvis Bay
- Real Name: Alex
jvt172 wrote:Mine also doing it. 2014 model 95000km on the clock
Some suspect it the tires, what are you running on yours?
Bonded to Yotas
- Thunder02
- Town: East Rand
- Vehicle: IFS Hilux
- Real Name: Neil
- Club VHF Licence: HC105
Could well be the tires, swop the two fronts around and see if the problem follows.
Scout motto:be prepared....
www.4x4direct.co.za
www.4x4direct.co.za
- Alex2539
- Town: Walvis Bay
- Real Name: Alex
Re: RE: Re: FORTUNER VIBRATES (ON THE PASSENGER SIDE) BEYOND 110 KM/H
Thanks will tryThunder02 wrote:Could well be the tires, swop the two fronts around and see if the problem follows.
Bonded to Yotas
- Dowe Koos
- Real Name: Hennie
Hallo Alex. Uit ondervinding, wanneer daar vibrasie is en jou stuurwiel skud van die vibrasie, dan kyk ons na die voorwiele se wiel balansering, wiel "alingnment" en "bearings". As die stuurwiel nie skud nie, kyk ons na die agterwiele se wiel balansering, wiel "alingnment" en "bearings". Ander ding wat ek ook al geleer het, buiten Neil se voorstel, vat die agterwiel aan die passessier kant, haal die die band af en draai dit 180 grade om ( selfde kant van die band met die selfde kant van die rim - moenie dit flip nie) Dit is nou as jou vermoede reg is waar die vibrasie vandaan kom.
- Alex2539
- Town: Walvis Bay
- Real Name: Alex
dankie, sal verdere ondersoekDowe Koos wrote:Hallo Alex. Uit ondervinding, wanneer daar vibrasie is en jou stuurwiel skud van die vibrasie, dan kyk ons na die voorwiele se wiel balansering, wiel "alingnment" en "bearings". As die stuurwiel nie skud nie, kyk ons na die agterwiele se wiel balansering, wiel "alingnment" en "bearings". Ander ding wat ek ook al geleer het, buiten Neil se voorstel, vat die agterwiel aan die passessier kant, haal die die band af en draai dit 180 grade om ( selfde kant van die band met die selfde kant van die rim - moenie dit flip nie) Dit is nou as jou vermoede reg is waar die vibrasie vandaan kom.
Bonded to Yotas
- isinyoni
- Town: Stellenbosch
- Vehicle: Hilux D4D
- Real Name: Marc
Yes, I agree and would look here. Also, have the rim checked for any flat spot or kink (buckled rim).Dowe Koos wrote:Hallo Alex. Uit ondervinding, wanneer daar vibrasie is en jou stuurwiel skud van die vibrasie, dan kyk ons na die voorwiele se wiel balansering, wiel "alingnment" en "bearings". As die stuurwiel nie skud nie, kyk ons na die agterwiele se wiel balansering, wiel "alingnment" en "bearings".
Currently Hilux Legend 45 D4D and Cruiser 100GXL
Veteran of many older Hiluxes and Cruisers
