Rubberizing
Looking for something? Ask for it here.
Mon Dec 17, 2018 6:44 pm
Where can I buy the same type of rubberizing which places like Rhino lining uses?
I want something which is the same soft rubbery stuff as Rhino lining.
Busy with a project which I cannot take to have rubberized so I want to do it myself.
Dirka
Town: Doornpoort Pretoria
Real Name: Dirk
Wed Dec 19, 2018 11:07 am
Pieter, the Rhino lining is a proprietary in-house product which are manufactured by their own chemical plant
in Johannesburg.
I don't think they put it in cans and sells it to the general public.
Maybe give them a shout and hear what they say? (011) 955-2555
071 8777 489 sales@rhinolining.co.za
The little I know is it contains Polyurethane, so maybe look for something similar that is available in the
shops, like the Duram DuraBak. Never used it before, but I hear good things.
” ― J. Kintz
Wed Dec 19, 2018 12:10 pm
Thank you, will try a sample of durabak
Hilux 1
Real Name: Tertius
Club VHF Licence: HC137
Thu Dec 20, 2018 11:18 am
Durabak is a DIY type rubberrizing, i had my whol trailor(more a suite case) sprayed inside and also the front so it is stone proof.
it is a water based product to, so pretty harmless
Thu Dec 20, 2018 2:49 pm
Ek sou gaan kyk wat hou die spesialis kar-verf plekke aan.
Thu Dec 20, 2018 3:54 pm
Somebody did this Jeep's floor with something which I presume is a water base because the whole floor under the "rubberizing" is rusted.
I presume they applied it to raw metal as I can see they welded in new plates.
One thing I cannot understand is how a water based paint can prevent rust. It is like Druam's NS4, water causes metal to rust.
Hilux 1
Real Name: Tertius
Thu Dec 20, 2018 4:08 pm
Pieter, daai water verdamp(volgen teorie), nie seker of jy verf moet verwyder en of jy dit net so op paint/spray nie. maar ek kna jou belowe daai ding sweet donners baie water uit.
Fri Dec 21, 2018 4:15 am
Ek kan nie dink dat jy die Durabak net so op die rou metaal kan verf nie. Jy sal hom eers moet voorberei met 'n onderlaag. Toe ek my Porsche spider gebou het in 1997 het ek die vloerpan in geheel skoon geskuur en toe ge-prime en gespray met 2K. Hierna het ek die onderkant grof gemaak en met Durabak gespuit. Dit is 'n bietjie "overkill" maar hy lyk vandag nog asof hy gister geverf is. Ek het hulle "stone chip" produk gebruik maar dit is ongelukkig nie rubberagtig soos wat jy verlang nie. Dis 'n baie mooi afwerking maar is klip hard.
Fri Dec 21, 2018 7:33 am
Dankie Marnus, daai maak sin
Sat Dec 22, 2018 2:40 pm
Rhino lining is poliuretaan - of te wel Polyurethane.
Dis 'n spesialis produk wat op presies uitgewerkte volumes of massas werk.
As jy bereid is om baie op te lees en toerusting(meestal 'n baie akkuratr skaal) aan te koop en tyd en geld het om te eksperimenteer, is ek oortuig jy sal regkom daarmee. Jy kan dit in baie verskillende hardhede maak.
Sikaflex of Den Braven se Polyflex is polyurethane.
Johan Kriel
Town: Okahandja
Vehicle: 2.5 SC 4x4
Real Name: Johan kriel
Sat Dec 22, 2018 4:49 pm
Daai rhino lining is op hulle beste crap, in die sin dat dit los kom, stukke uitbeek ens en nie behoorlik oral ordentlik kleef nie. Sal dit nie weer op n bakkie van my sit nie. Sal volgende keer n behoorlike rubberlining gebruik, of Line-X werk ook beter.
Johan Kriel
Prado
Mon Dec 24, 2018 11:46 am
:blushing:
As Rhino Linings los kom is die ou wat dit aangesit het se voorbereiding crap.
Daai goed klou soos twak aan 'n wol kombers as dit reg gedoen is.
In 1983 was my Pa een van die eerdte ouens in die land wat die masjiene gekoop het.
Elke middag van my laerskool dae in daai fabtiek deurgebring. Ek dink ek het seker amper elke moontlike goeie en slegte aanwending van die produk gesien. Goeie voorbereiding is maklik verantwoordelik vir 80% van die sukses.
Mon Dec 24, 2018 11:53 am
Johan my trokkie sin het ook losgekom, maar dit was omdat die ou wat dit opgesit het nie die bak grof geskuur het voor hy dit aangesit het nie. Hulle moes dit aftrek en oordoen en hy het nooit weer losgekom. Het self ook jare terug 'n Golf bakkie gehad met dit op en die trokkie het hard gewerk. Die Rhinolining was later al glad soos goed op en af gelaai was, maar dit het glad nie losgekom nie.
Johan Kriel
Town: Okahandja
Vehicle: 2.5 SC 4x4
Mon Dec 24, 2018 5:39 pm
Lyk my ek moet maar terug wat en oor doen, maar dit is nou 3 jaar later :D:
Johan Kriel
Prado
Fri Dec 28, 2018 4:48 pm
Ja is jammer jy het gewag, myne was iets soos 6 maande later en hulle het dit oorgedoen.
Return to “Wanted”
