99er mtb cycle tour
Do you prefer to 2 wheels to 4? Share your photographs and cycling stories here
Niel
Real Name: Niel
Thu Feb 07, 2013 12:11 am
Is anyone doing the 99er this weekeknd?
http://cycleevents.co.za/99er-cycle-tou ... enge-2013/" onclick="window.open(this.href);return false;
Polarbear2008
Real Name: Theunis
Club VHF Licence: X49
Thu Feb 07, 2013 1:29 pm
Die vraag is, gaan jy? ;)
Monroe Gas Magnum shocks
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
Thu Feb 07, 2013 1:30 pm
Die vraag is, petrol is mos nog nie so duur nie is dit?
ThysdJ
Club VHF Licence: HC102
Thu Feb 07, 2013 2:25 pm
Polarbear2008 wrote:Die vraag is, gaan jy? ;)
nee hy het sy fiets se kantwieletjies ge-buckle toe hy nou die dag geval het.. :twisted: :twisted: :twisted: :twisted:
Niel
Real Name: Niel
Thu Feb 07, 2013 11:09 pm
:D: ja ek was van plan maar toe koop ek grond :lol: nou eers op die krukke lys :thumbdown:
Donkey
Club VHF Licence: X122
Fri Feb 08, 2013 7:53 am
It's a bit far for me Niel, but on something else, but still on mountain biking, I keep on snapping my bike chains, I suspect due to me changing gears while standing at times, could this be? I keep the chain well lubed at most times.
Tumelo Maketekete
Polarbear2008
Real Name: Theunis
Mon Feb 11, 2013 10:47 pm
Thumelo
The main cause of chain breaks is a condition known as cross-chain. Say you have the front crankset on the smallest gear and the rear cassette on the smallest gear. This constitutes a very skew pull and puts immense strain on the chain. It also can cause premature wear on the chain link ends, which could cause a chain pin to drop out and hey presto, chain break!
You should also look at if you are in the correct gear for the gradient you are on. I recently read somewhere that (and this sounds logical but most of us never think about it!) you should adapt your gearing to the gradient of the terrain, for instance small gear on front crankset for steep klimbs, middle gear for less steep ones and the large for level and downhill runs. The rear cassette, you vary accordingly (keeping in mind to prevent selecting a cross-chain combination.)
Besides the fact that in the wrong gear you (and the drivetrain) have to work harder, you can injure yourself (especially knee-joints take a hammering!), so switch gears - that is what they are there for!
Read here:
"Andy Stanton
06-12-12, 09:05 AM
I went to my LBS yesterday because I noticed a funny sound coming out of the chain when my gears were in the 1 position at the front (left hand shifter) and 7 in the rear (right hand shifter). The mechanic told me that extreme positions (such as 1-7 or 3-1) should be avoided as they can put undue stress on the chain. I wondered if this were true or the mechanic was making an excuse to avoid fixing my chain.
Looking for an answer online I found this on Yahoo answers - does it make sense to you all?
If it's a 21 speed bike - that's actually a mis-nomenclature. There are NOT 21 "usable" gears. There are 13 "usable" gears. 2nd gear on the left or front shifter is used for most occasions. While in 2nd on the front - use any of the rear 7 gears. For uphill climbs - use 1st gear on the left or front shifter but ONLY gears 1,2 or 3 on the rear. For fast or downhill conditions - use 3rd on the front or left shifter - but ONLY 5,6, or 7 on the right side or rear shifter.
This prevents the chain being placed at too severe of an angle - known as "cross chaining". Cross chaining the bike puts too much stress on the chain causing premature wear not only on the chain, but the gears & derailleurs."
Found here: http://www.bikeforums.net/archive/index ... 24723.html" onclick="window.open(this.href);return false;
But I am sure I could find many more of the same elsewhere on the net.
Hope this helps.
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
ROOFER
Town: grassy park cape town
Vehicle: 99 s/c hilux 4x4 2.7i long range tank & dual battery; 2003 nissan x-TRAIL (4X4)
Real Name: charl
Mon Feb 11, 2013 10:57 pm
ja maar wat as n ou n dik wiel het sonder gears :?: :laugh2: :laugh2: :surrender:
Jaws
Town: Sharonlea
Vehicle: 2009 D4D 4x4
Real Name: Herman
Tue Feb 12, 2013 7:21 am
This my next challenge:
http://www.transbaviaans.co.za/" onclick="window.open(this.href);return false;
Really looking forward to August
:thumbup:
Hoppy
Vehicle: Hilux SFA & IFS
Real Name: Allan 0721291160
Tue Feb 12, 2013 6:18 pm
Donkey wrote:It's a bit far for me Niel, but on something else, but still on mountain biking, I keep on snapping my bike chains, I suspect due to me changing gears while standing at times, could this be? I keep the chain well lubed at most times.
:slap: Hou net die clutch in as jy gears change, dan sal dit nie gebeur nie.
Polarbear2008
Real Name: Theunis
Tue Feb 12, 2013 10:22 pm
:yahoo: :celebrate: :lmao:
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
Donkey
Sat Feb 16, 2013 8:32 am
I see Hoppy is on a roll here :lol: , but what you posted makes a lot of sense and have been trying it. Maybe it's time they make auto boxes :mocking:
Tumelo Maketekete
Return to “Cycling and Mountain Biking”
