toyota 4y
Discuss any other type vehicles here.
W0ODY
Town: durban
Vehicle: gwm
Real Name: videsh
Thu Dec 24, 2015 9:07 pm
Hi guys,I have a toyota 4y engine in my double cab bakkie,I heard abt the chevy lifters from masterparts n I have ordd them,I jus wanted to know if it will make a difference by changing my stock lifters with the chevy lifters,and if it jus swops out or if there is other steps for it to fit and work ...please update me with any info on this,and also contacts numbers where I can get mods to increase performance like cams,valve springs,etc...
The Legend
Real Name: Dawie
Club VHF Licence: X93-
Fri Dec 25, 2015 6:04 am
Hi Videsh
Welcome to the forum. I also replace the the lifters of my 4y engine with chevy lifters.I am very happy with it .It is very easy to replace them.
W0ODY
Town: durban
Vehicle: gwm
Real Name: videsh
Fri Dec 25, 2015 10:12 am
Ok that's great,so it jus simply fits it normal I take it?and wat differences did u find with ur new lifters ,does it rev higher or increse ur performance or acceleration ?
The Legend
Real Name: Dawie
Fri Dec 25, 2015 11:46 am
The chevy lifters is high revs lifters.Did not test it on my bakkie to see how high it can revs now.Can not say that I have better performance with it.
W0ODY
Town: durban
Vehicle: gwm
Real Name: videsh
Fri Dec 25, 2015 12:28 pm
Ok thanks for sharing,do u have any other performance mods or info where I can get cams,valve springs for my 4y
The Legend
Real Name: Dawie
Fri Dec 25, 2015 1:18 pm
Do a EFI conversion ,more power for the same fuel consumption as with the carb.
W0ODY
Town: durban
Vehicle: gwm
Real Name: videsh
Fri Dec 25, 2015 1:26 pm
Cums standard with injection,problem is it limits too early,at 4500 revs and gear ratios r way too short...
The Legend
Real Name: Dawie
Fri Dec 25, 2015 1:27 pm
Read this link for EFI conversion
viewtopic.php?f=92&t=676
The Legend
Real Name: Dawie
Fri Dec 25, 2015 1:29 pm
Read this link as well.It is a follow up on the previous one.
viewtopic.php?f=92&t=1172
W0ODY
Town: durban
Vehicle: gwm
Real Name: videsh
Fri Dec 25, 2015 1:56 pm
I've got fuel injection already bro...I want to modify the head abit with bigger valves ,valve springs,lifters n a custom performance cam
W0ODY
Town: durban
Vehicle: gwm
Real Name: videsh
Sat Dec 26, 2015 12:58 pm
Do I need to send the head to engineers after putn the chevy lifters?does the lifters need to be set or checked for clearance ?
The Legend
Real Name: Dawie
Sat Dec 26, 2015 1:07 pm
You do not have to remove the head to replace the lifters.You only remove the tappet cover ,rocker shaft with rockers and pushrods.No adjustments needed for valve clearance.It is an hydraulic system.Remember to bleed the new lifters before installing them.
W0ODY
Town: durban
Vehicle: gwm
Real Name: videsh
Sat Dec 26, 2015 1:12 pm
Ok perfect,was jus worried abt clearance ,and is there any other mods u know off for the 4y?please let me know
Return to “Any Other Vehicle”
