Resizing Pictures the easy way!
Posted: Wed Oct 28, 2009 7:03 am
by CasKru
Hey guys and gals. I found a nice little application (for free) which you run on your pc. When you copy pictures into a specified directory it will automatically resize / resample the images to the specifics you set up in it's settings.
Check out this link:
http://www.dropresize.com/
Here is an example of a file I resized this way (orig size 2272x1074 & 916Kb)(new Size 800x600 & 62Kb)
Re: Hate resizing pictures to post?
Posted: Wed Oct 28, 2009 7:44 am
by Hannes.S
Thanx!
Het al bietjie gaivol geraak vir resize! Dit gaan die lewe baie makliker maak!.
Posted: Wed Oct 28, 2009 7:47 am
by Bushwacker
Thanks Cassie, I moved pics to a dedicated folder, but the size remains the same?
Posted: Wed Oct 28, 2009 7:55 am
by ThysdJ
Posted: Wed Oct 28, 2009 8:02 am
by CasKru
Bushwacker wrote:Thanks Cassie, I moved pics to a dedicated folder, but the size remains the same?
Also thought so the first time round. Just close the folder and open it again. When you first paste it, it seems it show the properties as at the time when pasting but when you "refresh" you will see that the properties has changed.
Posted: Wed Oct 28, 2009 8:08 am
by ThysdJ
Posted: Wed Oct 28, 2009 9:01 am
by CasKru
Just make sure your PC is runnig .Net framework 2 (should be if you run the auto updates).
Kan nie glo hoe maklik dit nou eintlik is nie :)
Posted: Wed Oct 28, 2009 9:11 am
by ThysdJ
Posted: Wed Oct 28, 2009 9:16 am
by the BuTch3R
What a pleasure! Thanks Cassie
Posted: Wed Oct 28, 2009 9:31 am
by Bosfebok
Lekkelekke
Posted: Wed Oct 28, 2009 10:19 am
by ThysdJ
Posted: Wed Oct 28, 2009 10:20 am
by CasKru
Posted: Wed Oct 28, 2009 10:24 am
by ThysdJ
okay ek maak so...
Re: Resizing Pictures the easy way!
Posted: Wed Sep 05, 2012 11:46 am
by Frederick
Goeiedag,
Werk die dropresize ding nog?
As ek op hom kliek dan wil hy nie die website oopmaak nie
Posted: Wed Sep 05, 2012 5:01 pm
by Rooies
Posted: Sun Feb 23, 2014 12:50 pm
by Pieta1WP
Ek
weet nie van julle nie,maar ek verstaan nie japenees nie.
Posted: Sun Feb 23, 2014 2:48 pm
by Genissie
ek sukkel netso met di snapsnees
Posted: Mon Mar 10, 2014 11:48 am
by Cleaner
Dropresize can be downloaded
here - The original website does not exist anymore!
