zero appliance
Posted: Wed Aug 13, 2014 6:57 pm
by mcw
Was given this gadget last week
any body know how to operate this
there is no instruction booklet with it
Re: zero appliance
Posted: Wed Aug 13, 2014 8:24 pm
by Thunder02
Yip, used to have one myself.
Very sensitive to not being level.
Really nice units,220,12V and gas.
Will give you a demo when i see you again.
:thumbup:
Re: zero appliance
Posted: Wed Aug 13, 2014 9:47 pm
by Family_Dog
Absorbtion fridge. As Neil said, it has to be level for it to work. Finicky, but when they work they work well. You might have to turn it upside down or shake it about if it does not work, and then try again.
Re: zero appliance
Posted: Wed Aug 13, 2014 9:57 pm
by mcw
After much painstaking inspection of the fridge and procastenation on my part my wife plugged it into 220v plug and it works prefectly
Will have to get new wife ,this may know to much
Re: zero appliance
Posted: Wed Aug 13, 2014 10:55 pm
by Obelix and Dogmatix
google is your friend. I googled them the other day and yo can download intructon manuals from the site.
Re: zero appliance
Posted: Wed Aug 13, 2014 11:52 pm
by STAMPIE
I also had one.
Excellent little fridges. Good on gas and 220v.
I use to travel with it on 12v, but then it it's just cool, not cold, due to the fact that it is constantly moving and not perfectly level.
After 16 years it is still working fine.
zero appliance
Posted: Thu Aug 14, 2014 6:18 am
by grobbepj
Hi Martin,
Ek het n soortgelyke een by toppie4x4 op die forum gekoop en toe bici later nog n tweede een ook aangeskaf teen baie billike prys. Hulle werk great op gas en 220V, maar soos stampie se in die kar nie altyd 100% (moet level staan). Maar as hy koud is voor jy hom in die kar sit het jy geen issues. En daar is geen bewege de parte wat kan breek op n roete nie. Jy moet hom ok net so dag of wat voor die tyd al aansit op 220V om hom mooi koud te kry. Ni so vinnig soos die nuwe yskaste. Maar hy vries water kliphard as hy eers koud is (koudste setting). As ek so loer na nuwe yskas pryse gaan ek myne nog laaaank hou...
Geniet hom.
Re: zero appliance
Posted: Thu Aug 14, 2014 7:07 am
by Family_Dog
I used mine in while towing my caravan with it switched on, it seemed to work even better when in motion. Guess all the bouncing around helped the gases to flow. You might have suffered a voltage drop at the element thus leading to lower efficiency, think they were quite hefty at around 100W or so.
Re: zero appliance
Posted: Thu Aug 14, 2014 7:31 am
by mcw
Tks for all the info
i have a 40l engel as well this will be second fridge which i am going to install in cabin ,after removing back seat,what i like about this model it does not make a noise at all
Martin
Re: zero appliance
Posted: Thu Aug 14, 2014 8:35 am
by janvg
Im still using mine. Took it to work and use it everyday.
Re: zero appliance
Posted: Thu Aug 14, 2014 8:55 am
by Vlak vark
just make sure that the chimney is open and clear from any obstruction. if chimney gets to hot it also wont freeze. good value for money. use mine at home. :thumbup:
Re: zero appliance
Posted: Thu Aug 14, 2014 2:43 pm
by mcw
Tks mine is perfect value as I was given this for free by my ouboet
Mine
Re: zero appliance
Posted: Thu Aug 14, 2014 5:43 pm
by Thunder02
Martin, i see a big problem with that fridge, there's no beers in it :thumbdown:
Re: zero appliance
Posted: Thu Aug 14, 2014 9:24 pm
by pietpetoors
Ha Ha, zero appliance with zero manual!
Re: zero appliance
Posted: Fri Aug 15, 2014 7:05 am
by Thunder02
pietpetoors wrote:Ha Ha, zero appliance with zero manual!
And zero beer....
Re: zero appliance
Posted: Fri Aug 15, 2014 9:24 am
by mcw
Saving all the beers for December trip to Bots, wife will have to drive
Martin
Re: zero appliance
Posted: Fri Aug 15, 2014 3:53 pm
by Borntofish
That fridge is a bit on the small side then...
Re: zero appliance
Posted: Sun Aug 17, 2014 12:13 am
by cyborg
I have a similar fridge, and I have found that it works best on Gas.
Re: zero appliance
Posted: Sun Aug 17, 2014 7:16 am
by Thunder02
mcw wrote:Saving all the beers for December trip to Bots, wife will have to drive
Martin
:laugh2:
Re: zero appliance
Posted: Mon Aug 18, 2014 2:03 pm
by Haboob
Had 2x70L Zero Deepfreezes. Work very well. Just don't leave it connected to your vehicle battery when engine not running as it will flatten the battery in next to no time...
