Australian Revolver shackles double twist and lockable
- SYRON CONVERSIONS
- Town: Tamboekieland
- Vehicle: SFA HILUX
- Real Name: SIMON
These shackles can be fitted at the rear of the vehicle and as well at the front leaf spring blades at their rear, but a special trac bar is required as well as longer shocks, we also have a special joint that we will also be using, will find a photo of this joint, it will be incorperated into the eye of the main blace of the spring pack, will protect the blade against damage when it twists.
Ask questions if you have any?
simoan
simoan
- Jurgen
- Vehicle: 1998 LR D1 V8i
- Real Name: Jurgen
Re: Australian Revolver shackles double twist and lockable
Some advantages are obvious, but could you please list some less obvious advantages?
1998 LR D1 V8i
1989 Toyota Hilux 2200 DC 4x4 - sold with fond memories
