IFS- ABS warning light when connecting caravan trailer plug.
- Polarbear2008
- Real Name: Theunis
- Club VHF Licence: X49
I am stumped and totally confused.
Whenever I connect my standard caravan trailer plug to the Lux, whith engine off or not, soon after the ABS warning light comes on. This only happens when the trailer plug is connected.
I have double checked the trailer plug on the caravan's side, everything looks fine.
My question is this - the standard loom that comes with the Hilux trailer connection, has different colour coding to the "standard" Hella colours, for instance, there is a RED and GREEN cable that I cannot find out what it is for. I have managed to find all the other functions: i.e. indicators, brakes, taillamps, etc.
I recently replaced my rear bumper after a coming together of my drawplate with a stubborn rock! but the problem existed before the replacement, in fact it was so since I bought it. Even had it with the sellers soon after I discovered it, but as I said, it seems to only happen when the trailer plug is connected.
Any help, and especially a wire colour chart for the lux side of the plug would come in at 110%
Thanks in advance
Thanks in advance
Monroe Gas Magnum shocks
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
- Town: PE
- Vehicle: 2700i D/C
- Real Name: Craig
Re: IFS- ABS warning light when connecting caravan trailer p
I have attached the SABS Diagram
Pin 2 is Auxillary or to charge trailer Battery / Fridge
- Attachments
- Trailer_Plug.pdf
- (17.72 KiB) Downloaded 101 times
05 Hilux 2700i D/C Legend 35 4x4
- Polarbear2008
Hi
Dankie
dis soos ek hom ook het, maar die ABS liggie storie het my totaal "confused".
Kan nie verstaan hoekom dit gebeur nie....
Dankie
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
- george
- Town: Velddrif
- Vehicle: Triton 3.5l V6
- Club VHF Licence: HC107
Hi Theunis.
Het jy al 'n oplossing vir jou probleem.
my ABS liggie het ook gister aangekom toe ek my boot sleep
Toe ek nader ondersoek doen toe sien ek dat as my flikker aan is en ek trap briek dan verdoof die flikkers en die brieke flikker van die sleepwa.
Ek gaan 'n ander "earth" draad insit en kyk of dit werk.
- Polarbear2008
Ek gaan dieselfde probeer - meeste ligte issues (other than ABS warning :wth: ) het te doen met slegte earth.....
Het 'n trailer gehad wat sulke disco ligte gemaak het totdat ek die earth reggestel het.....
Sal laat weet wat gebeur....
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
- george
- Town: Velddrif
Hi Theunis
My nuwe earth draad lyk of hy die job gedoen het
- Polarbear2008
George
Die earth waarvan jy praat - was dit op die trailer? En was dit aan die ligte se kant, of die trailer plug se kant?
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
Die Toyota wiring loom het NIE n earth draad nie. N kort stukkie groen draag word bygegee, die word dan vasgeboud waar die lig socket aan die towbar gebout word - perfekte resep vir n swak verbinding.
Lê n ordentlike earth aan en kyk wat hy maak.
- warthog
- Town: Barberton
- Vehicle: Fortuner 4.0 V6 Auto, LRFT, Dual Batt, OME's, BFG AT's, ARM comp, 800w inv, Roofrack
- Real Name: Hennie
Nou weet ek hoekom Forest se ABS liggie aankom as ek die baba-wa sleep...
Dit het nog nooit gebeur as ek die Hump sleep nie...
- george
- Town: Velddrif
Ek het 'n nuwe earth op die bakkie se kant gesit
- george
- Town: Velddrif
Hi Theunis het jy toe reg gekom?
My ligte disco nog steeds en die ABS se liggie het ook weer aangekom
Check the earthing right at the light enclosures on the trailer. They're also prone to have bad earthing. Could also be an incorrect bulb (single action in a double action slot) that causes the problemgeorge wrote:Hi Theunis het jy toe reg gekom?
- mtbbiker
- Town: Centurion
- Vehicle: Toyota hilux 2700i 4X4DC
- Real Name: Eugene
- Club VHF Licence: B199
Hi
I had the same issue, earthing it properly fixed it !
- Johannes van die See
Klap die dashboard!
Nee ouens regtig, dit het met my ook gebeur, toe klap ek die dashboard.
Daarna het ek by PietPetoors se huis gestop, toe gee hy my n nuwe fuse wat ek in gesit het, toe werk alles reg.
Ek is seker die dashboard het iets daarmee te doen. :?
Just remove the ABS warning light globe... problem solved...
- Town: polokwane
- Vehicle: hilux
- Real Name: ruhan
hi ouens
ek wil nie hijack nie .... weet julle miskien of die gloeilamp van die abs nog iewers verktygbaar is?
dankie
dankie
as dit nie n toyota is nie........... dan is ek nie verslaaf nie
Hey Baardman, waar kry jy daai naam?mandevu wrote:hi ouens
dankie
Dit is nogal legendary!
- Town: polokwane
- Vehicle: hilux
- Real Name: ruhan
dra baard al vandat uit die skool is...
my werkers het my dit begin noem....
Ek het so iets gedink ja, Fanagalo, dis n clasic naam hoor, ek het ook n Mandevu na aan my hard.mandevu wrote:dra baard al vandat uit die skool is...
Dis n naam van respek, veral as dit van die werkers af kom,
- Town: polokwane
- Vehicle: hilux
- Real Name: ruhan
