Long range tank: 70L or 100L
- Jaco Versfeld
- Town: Western Cape
- Club VHF Licence: X69
Hi there,
What other considerations are there when deciding between a 70L and a 100L long range tank?
The 100L tank will drop the spare wheel a bit more, couple of cm. Will this have a major effect on the break-over angle and approach angle?
Will the weight be a problem?
Thanks,
Jaco
Thanks,
Jaco
Re: Long range tank: 70L or 100L
100l v 70l yes, it will certainly drop your spare wheel if you fit a 100l. especilly if diving with the spare wheel underneath. If you are not too much into tail / track driving I would go for the 100l. But have it custom built. The chap at Silverton Radiators Kdp West can help you with that.What other considerations are there when deciding between a 70L and a 100L long range tank?
- cprinsloo
- Vehicle: 1998 D/C 4x4
- Club VHF Licence: X52
The conventional LR tanks can be a problem depending what you plan to do. I've read of spare wheel being ripped off in Khaudom (high middelmannetjie), and I guess it can also be a problem during trails.Jaco Versfeld wrote:Hi there,
Thanks,
Jaco
Also, all the weight is behind the rear wheel, which can maybe affect handling. Why not consider another standard tank on the left-hand side? You'll have to modify the exhaust a bit, but the tank will fill quicker.
C
1998 Hilux D/C Lexus VVTi
I have a 120L LR tank fitted to mine with a full size spare. It hangs lower than the towbar but according to me not much of a problem. So far so good.
I must admin that the 120L tank now only holds 115L due to it being dented after an extremely hard knock from below on the spare. The kind of know I am referring to is if you hoist the rear of your bakkie 1m of the ground and drop it so that the spare wheel hit something solid when the wheels touch the ground.
- Town: Howick
- Vehicle: 1998 Hi-lux 2,4 S/cab (p); 1997 Hi-lux 2,4 D/cab (p)
- Real Name: Harold
Refering to the SFA Hilux:
Besides tank capacity, what do you do about the spare wheel?
The usual ratchet system for rising and lowering the spare wheel is a nightmare as it becomes clogged with dust and mud. Bad enough without an additional fuel tank, at least you can get to it with Q20 or silicon spray; but what the hell do you do when it is snugly under the additional fuel tank and will not budge?
The weight factor of having a spare wheel carrier at the back is also not an option..
It looks real macho and is probably OK provided that you stick to good roads; but you could have serious problems if you do long trips on ‘real’ bad roads.
The best option would be to modify the exhaust and fit another tank on the passenger side, opposite the existing tank.
There is more than enough space on the drivers side for a 100lt tank, (I know as I have one). No doubt the passenger side could also take a 100lt tank – not sure what you would do with the exhaust – maybe change your snorkel to an exhaust?
Harold (Greytown, KZN)
- cprinsloo
I'll try and finr the trip report where I read of the spare being ripped off. I believe it is possible, some roads in Bots and Nam, driven with a fully laden vehicle, are really scary.CasKru wrote:I have a 120L LR tank fitted to mine with a full size spare. It hangs lower than the towbar but according to me not much of a problem. So far so good.
C
Reason: update quote
- cprinsloo
Funny you should mention it, I had to saw through the last link of the chain once, not nice.....Harold wrote:Refering to the SFA Hilux:
- Town: Port alfred
- Vehicle: 2008 Fortuner V6 4x4
- Real Name: Daryl
If you are going to have say 2 x 100lt tanks built and put one on either side of your vehicle, what material do you use to build them? Someone told me once that you don't build a petrol tank from stainless steel as it tends to sweat, then gets a layer of water on top of the fuel. Is this true? Aluminium would probably be a bit soft, especially if you hit a rock, and I would think you would need at least a 1.6mm steel plate for the weight of the fuel and for it to be robust. Any suggestions?
Unfortunately I haven't been able to do a lot of over landing yet and cannot comment on their roads. I'm sure under the right circumstances anything is possible. Just saying it is unlikely to happen.cprinsloo wrote:I'll try and finr the trip report where I read of the spare being ripped off. I believe it is possible, some roads in Bots and Nam, driven with a fully laden vehicle, are really scary.CasKru wrote:I have a 120L LR tank fitted to mine with a full size spare. It hangs lower than the towbar but according to me not much of a problem. So far so good.
C
If I could I would remove the spare all together from below the vehicle. Chances are where you get the puncture it will almost be impossible to get to it and first need to drive a bit further or raise the bakkie first, get the spare, lower the bakkie, lift the bakkie at the flat wheel, swap the wheels, lower the bakkie, lift the back of the bakkie, store the flat in the spares place and lower the bakkie again.
- Town: piketberg
- Vehicle: hilux 4x4 sfa
- Real Name: richard
- Club VHF Licence: no
Looking for a long range tank for my sfa surf, dont want a spare under the truck its a mission to get out, the rachet winch to hold the spare under there gets jammed up then its not easy to get out, then you got to jack up your truck higher to get under it and cut the last link in the chain. 2.5 hours to change a tyre did not impress SWAMBO who made lunch. Lunch was very good though.
Keep the spares on the roof rack now.
- arnize2
- Town: Wellington
- Vehicle: 2008 Toyota Hilux 3.0 D4D D/C 4X4
- Real Name: Arno
Het in my vorige bakkie die tenk bokant die noodwiel gehad. By verskeie geleenthede gekap en/of gesleep. Sal dit nie weer so doen nie!! Gaan nou die ander roete volg. So oor drie weke.
