Centre bearing
Centre bearing
Maybe someone can help. What would be the symptoms of a failing centre bearing? What should I be looking / listening for?
Re: Centre bearing
Cassie very simple to test... support the rear prop(else it will pop out), loosen the centre bearing's 2 securing bolts, drop the centre bearing so the housing can spin around without knocking anything, spin the bearing around, feel and listening for any vrot bearing noises like metal to metal grinding/dryness, or stiffness when rotating... check as well for perishing/cracks in the rubber housing around the bearing... check as well that the rubber hasn't collapsed... if needed... replace... else just put the 2 bolts back and tighten...
Mr B
Mr B
Re: Centre bearing
Thanks Bretton. Will try that this weekend. Got a weird sound emitting from the drive train somewhere. My first thought was that it is the pinion bearings as the diff had leaked oil and it took about 2 bottels of oil to fill. But this weekend felt for play at the diff and I can hardly move the prop from side to side where it goes into the diff. So it is either the centre bearing or the internals of the rear diff
Re: Centre bearing
I also had a strange noise coming from under the vehicle, Allan told me how to test the centre bearing, which I did(as I described above)... was fine... then we jacked the rear up and ran the drivetrain with the rear wheels off the ground... Dr Allan Venter got underneath with his stethoscope and investigated... turns out the rear diff pinion bearing is on it's way out... maybe you can do the same to diagnose?
Mr B
Mr B
Re: Centre bearing
Shot.... will give that a go... first have to make a doctors appointment and nick his stethoscope when he is not watchingMr_B wrote:I also had a strange noise coming from under the vehicle, Allan told me how to test the centre bearing, which I did(as I described above)... was fine... then we jacked the rear up and ran the drivetrain with the rear wheels off the ground... Dr Allan Venter got underneath with his stethoscope and investigated... turns out the rear diff pinion bearing is on it's way out... maybe you can do the same to diagnose?
Mr B
Re: Centre bearing
Sorry Cas... a normal doctors stethoscope won't do... you need a mechanic's stethoscope... so there goes the 'We can play doctor nurse after I've used it on the Lux'... idea...
Re: Centre bearing
Mr_B wrote:Sorry Cas... a normal doctors stethoscope won't do... you need a mechanic's stethoscope... so there goes the 'We can play doctor nurse after I've used it on the Lux'... idea...
Then I will have to use my multimillion rand stethoscope I've got (a 1m length of hosepipe )
- Shamrock
- Town: Rustenburg
- Vehicle: 1998 Hilux 2.4 4x4
Re: Centre bearing
I think I have the same problem, Piet petoors also described the same problem a while back if I remember correctly, 4th and 5th gear between 2000 & 2500rpm. What does such a repair cost?
Wil it be easy/fast enough to do it myself?
Re: Centre bearing
Don't know what it would cost but got prices on the parts at McCarthy Toyota Midrand and they are as follow:
Pinion Bearings R244,51 & R546.43
Pinion Oil Seal R 115.56
Pinion R 969.11
Crown Wheel R2699.57 or R3110.68 depending on type of axle.
I think worst case it would probably be the two bearings and seal to be replaced. So you are looking at about R1K. I got a price on the centre bearing at some stage and if I remember correctly it was in the region of R1300.
You will be able to replace the bearings and seal your self if you have a bearing puller and a toolkit. The problem is setting the backlash
Pinion R 969.11
- Shamrock
- Town: Rustenburg
Re: Centre bearing
Well, I have access to all the tools I can dream of, thanks to my FIL. But how does one set the backlash?
- swartvark
- Town: Gordons Bay
- Real Name: Tiaan
Re: Centre bearing
Die ouens by Trend Tyre op Springbok het my centre bearing vervang oppad terug uit die Richtersveld. Hulle het R790.00 gevra vir die hele job.
MUD........GLORIOUS MUD!!!!!
NEED A CAR?
talk2tiaan@gmail.com
0829294028
Re: Centre bearing
Daai is impressive... hoe het hulle die bearing vervang terwyl julle gery het?swartvark wrote:Die ouens by Trend Tyre op Springbok het my centre bearing vervang oppad terug uit die Richtersveld. Hulle het R790.00 gevra vir die hele job.
Sorry.. moes net. Weet jy watse maak bearing hulle gebruik het?
- LouisZ
Re: Centre bearing
Hallo Cassie,
Kyk of die rubber geperish is, dan ook dieselfde soos ek jou gese het om by die diff te doen. Beweeg die propshaft direk lanks die centre bearing op en af en heen en weer. AS die meer is as >15mm is dit tyd.
Nog iets om te kyk na is as die propshaft le onder teen die centre bearing. Ook as jy sien die bearing en die rubber in die centre bearing is los van mekaar.
Luister; as jy geskuur en ook 'n vibrasie voel van die propshaft.
As die centre bearing reg is sal jy sien die prop loop reguit deur met so angle effens na die agter diff, dis normaal. Ook daar sal baie min beweging wees.
Het jy al een vervang?
Re: Centre bearing
Ek self het nog nooit een vervang nie en ek weet ook nie of die vorige eienaar al het nie. Ek dink ek gaan begin kyk by die centre bearing en dan na agter toe werk. As ek hom replace en die ander een was nog 90% fine, dan hou ek die ou een vir spare sou die nuwe een iewers in die veld kalf. Dan het ek darem 'n spare om tot by die huis te kom. :) Ek is nou maar ongelukkig eenmaal so. As iets vir my net begin suspect klink dan vervang ek eerder as om langs die pad te gaan staan en hom dan te probeer vervang. M.a.w. guilty until proven innocent4x4megaworldpta wrote:Hallo Cassie,
Re: Centre bearing
Okay so toe vat ek nou my diff vir Louis om die bearings en seel te vervang en toe bel hy my so paar minute terug. Die crown wheel en pinion het ook seer gekry
Re: Centre bearing
I know where you can get a C&P with a ratio of 4.1... but unfortunately that is not the ratio that you want.
Re: Centre bearing
Actually though of thatFamily_Dog wrote:I know where you can get a C&P with a ratio of 4.1... but unfortunately that is not the ratio that you want.
Toyota Midrand can only get in 21 days. Toyota in Benoni might be able to get me some by Monday. I'll probably pop in at Gemini on Saturday and see what they've got.
- Vlak vark
- Town: Phalaborwa
- Real Name: Nico
Re: Centre bearing
Hi Cassie.
Het my lux se senter bearing vervang 2 weke terug. dit is baie vinning. die langste is om die bout op die propshaft los te maak. die res maklik. pasop net om die propshaft nie ovaal tedruk in die weis nie. die bearing het R460 by Midas in phalaborwa gekos. wat ek wel gedoen het om meer suport op die beaing te sit, het ek van die gate toegeplak en die holte tussen die bearing en die housing met sililon ingespuit wat dan die rubber suport.
