So my mechanic is replacing the Front brakes etc and upon opening up the hub we found that the right hand side was missing the splined washer and circlip that prevent excessive movement of the driveshaft.
Toyota says the washer does not come by itself - over R2000 for entire thing. What alternatives do I have?
Thanks!
Circlip and Splined washer front right 2.7
Re: Circlip and Splined washer front right 2.7
Tristan, can you post a pic or 2 of the parts needed... will help identifying if someone has for you!
Is it not an option to remove the other sides... and have an engineering works make you one?
- Town: port shepstone
- Vehicle: IFS HIlux 2700I 99
- Real Name: tristan
Sounds like a good plan! Thanks.
They can't do the splines - so it will just be a washer without splines, should do the job.
I'm sure they could laser cut it using the one you got as a template! Worth a ask!
- Piesang
- Town: Grabouw
- Real Name: Pieter Pieterse
Gee vir my die binne en buite mates van die washer en c-clip
- rock solid
- Town: Grand Junction
- Vehicle: 85 extracab
- Real Name: philip
is the washer 27 spline?
ive got at least 10 of those layin around my garage
Yeah I thought there must be quite a few lying around in various mechanics bits&pieces boxes Anyways an Engineering firm, Allan and Sons did me one for R80. I got the cir-clip from the agents for R21. So it fits and I don't think the splines are totally necessary, the older Hilux's and Izuzu's don't have the splines.
So far i have saved a few thousand as I also declined to purchase the aircon and steering pump tension pulleys from toyota at R500 each and just banged out the old bearings and paid R100 for new bearings according to the advice here http://www.hilux4x4.co.za/replace-tensi ... /index.php" onclick="window.open(this.href);return false;.
Thanks for all the help!
- Piesang
- Town: Grabouw
Bly jy het reg gekom, wat die bearing aanbetref wat op die aircon/steering pump tension pulley werk, maak seker jy gebruik 'n bearing met 'n C3 gradeering. Daar is ook 'n paar ander maak bearings dan NSK wat baie goed is bv NTN, otherwise, TIMKEN, UBC en SKF wat ons aan die ouens verskaf.dotcatt wrote:Yeah I thought there must be quite a few lying around in various mechanics bits&pieces boxes Anyways an Engineering firm, Allan and Sons did me one for R80. I got the cir-clip from the agents for R21. So it fits and I don't think the splines are totally necessary, the older Hilux's and Izuzu's don't have the splines.
Die C3 beteken die bearing kan teen 'n hoër tempratuur werk as die sonder die C3, wat goed werk by die engin.
