Sound from axle/diff
- Town: Midrand
- Real Name: Nishan
I get a sound from the diff/axle as it locks in.
This happens as i leave the clutch on gear. As soon as there is drive going to the wheels there is a "clunk" as the diff engages. However it doesnt always happen.
A friend says this is normal but it irritates the h@#ll out of me.
is it normal? What can i do to fix it?
Real drivers use three pedals
Re: Sound from axle/diff
Have the same. It's the play (backlash) on the pinion and ring gear (crown wheel)Die$eL wrote:I get a sound from the diff/axle as it locks in.
- TOKKELOS 1
- Town: krugersdorp
- Vehicle: TOYOTA
- Real Name: RICHARD
One of two things phone me and I will explain
hoekom?WANT EK KAN!!!
B-CON 4X4 Accessories - Bumpers, snorkels, rock sliders
Tel: 0734378215 or www.bcon4x4.co.za
- Town: Midrand
- Real Name: Nishan
@ CasKru: Is it a problem?
will it cause other issues?
@Tokkelos - I dont have your number...
- TOKKELOS 1
- Town: krugersdorp
- Vehicle: TOYOTA
Cell 0734378215Die$eL wrote:@ CasKru: Is it a problem?
When you've spoken to Regard, Please post his answer here so we can seeDie$eL wrote:@ CasKru: Is it a problem?
- Town: Midrand
- Real Name: Nishan
I spoke to Richard
he says it could be: (forgive me if i get this wrong)
- worn splines on the front flange going to the diff
- worn centre bearing
- the rear flange
the bakkie is going in for service next week or so and also to sort the leak on the tranfser box. Will get them to check it and post an update.
Thanks for the info guys and Richard please forgive me if i got anything wrong above... :)
- the rear flange
:wth: :wth:Die$eL wrote:I spoke to Richard
- the rear flange
So it seems I will have to check mine out then too... if I have to take a wild guess on my side it will be the centre bearing
- Rebel 4x4
- Town: Port Elizabeth
- Real Name: Thomas
I see you've got a locker, reason why I mentioned it, its because if you've got a lock-rite locker or something of that sorts, you'll here that sound on occasions. I've got the same sound sometimes, it makes a horrable sound suddenly, like someone has shot you with a shotgun. Everybody that got a lock-rite locker has told me that........
- Shamrock
- Town: Rustenburg
- Vehicle: 1998 Hilux 2.4 4x4
Cassie, ek was nie vir lank nie op die site nie , klink jou diff nou beter nadat jy die bearings geruil het?
- Town: Midrand
- Real Name: Nishan
So the bakkie is currently at the Mac
he called me now and says that the U-Joint is stuffed.
He didnt give me a price yet. What should i be expecting to pay?
also, i am going to need to do the brakes front and back and skim the front discs. Any idea on prices for that?
- Town: Springs
- Real Name: Heinrich
- Club VHF Licence: X81
Nishan on the discs the prices will be dictated by who does the work, but expect an average price of R900-00 (you only have discs front). Just be certain the mechie is not up-selling the service on the brakes. He will probably get an outside service provider and then as franchised dealer add something like 45% mark-up.
Astrobrake does on car skimming at R200-00.
Know what you don't know.
Louis at 4x4Megaworld did the complete inner part of the back diff... bearings (pinion and carier), crown wheel, pinion and it is running very quite now :)Shamrock wrote:Cassie, ek was nie vir lank nie op die site nie , klink jou diff nou beter nadat jy die bearings geruil het?
- Town: Springs
Other advice would have been pro-nutro or banana's, they also make a diff run smooth (for a while).
Jy was seker 'n LR machie op 'n tyd..Traveler wrote:Other advice would have been pro-nutro or banana's, they also make a diff run smooth (for a while).
- Town: Springs
Nee, daai het ons sommer gehardloop op molasse.....CasKru wrote:Jy was seker 'n LR machie op 'n tyd..Traveler wrote:Other advice would have been pro-nutro or banana's, they also make a diff run smooth (for a while).
- Town: Midrand
- Real Name: Nishan
So i had the U-Joint replaced. Cost R750 with labour
What a difference!!!! :!: :!:
Bakkie is smooth between gear changes and the vibration/shudder that was there around 120km/h is gone.
Feels like a different bakkie :!:
However, he tested the battery and its on its way out.
Anyone can get batteries at a good price
