Chassis galv or spray
- dustbuster
- Town: Richards Bay
- Vehicle: Rebuilding 91 D/C Hilux Mboza Body, OME 4Y EFI, & 91 S/C 4Y Hilux
- Real Name: Dean
Hi thought I would ask which is the best way to sort out my chassis, there is no rust on it luckily but does need some attention.
Should I sandblast it then get it acid washed then hot dipped galvanized or just sandblast and the re-spray it?
Will hot dip galv damage it at all friend says it might warp it? I know I will have to re-tap all the bolt holes or put bolts in the holes before it gets dipped
Re: Chassis galv or spray
My 5c worth:
Galvanize!!
Galvanize!!
- Club VHF Licence: X93-
Thabogrobler wrote:My 5c worth:
Galvanize!!
- dustbuster
- Real Name: Dean
ya I also think it is the way to go, just have to try do my best to get the rubbish out the inside the chassis before the dip it
Hot dip will not warp it. If your galvaniser is diligent, he will treat the threaded holes / riv-nuts before galvanising so that it doesn't 'take' in the treated threads and you don't have to re-tap them (you might just have to 'clean up' some of the mounting surfaces a little if they're a bit rough). Clean out what you can if there is dirt and grime inside the rails, but they will acid dip it first anyway.
Far better than spraying, and not much more expensive, especially if you take your labour into account.
If however you intend to paint it after galvanising instead of just leaving it raw, tell your galvaniser of your intentions so that he does not dip it in a pacifier after the hot dip. You should in any event still use a galvanising cleaner before painting with an etch primer (NOT water based) .... red oxide still works well, but there are some that are specifically formulated for application to zinc
No man, just leave it as is after galvanizing - looks great!
AgreeThabogrobler wrote:No man, just leave it as is after galvanizing - looks great!
- AM Racing
- Real Name: Dylan
The best thing for the bolt holes is wooden dowels. Just smack the appropriate size dowel in the holes ie. 8mm hole: 9mm dowel It must just be tight. You can clean them afterward with the correct tap.
Not sure if the dowel will work, Dylan ... it might, but it'll burn up in seconds. The local guys once told me what they do and it works .... I've never had issues. Can't remember what they do for the internal threads, but the external ones they just put some plain masking tape. Of course it burns away immediately, but the residue that it leaves on the threads is not removed by the surface flux in the dip tank and so the zinc doesn't coat them. The same principle is used for the internal threads ... damn! Wish I could remember what they told me.
- Town: Adelaide
- Vehicle: Toyota camry altise. Till I find a replacement hilux.
If its for a older shape land cruizer then its a bad idea. The chassis is made to twist when off roading and galvanising will make it to riged. So when it does eventually get to a point of twisting it cracks the galvanising and rusts the chassis at that point.
There is a madness about been mad that only a mad person can understand.
Diesel and dust is where home is at.
- dustbuster
- Real Name: Dean
all done now I have to decide to paint or not to the galvanize will fade eventually, if I want to spray it I must first wash it with a galv. wash then I can spray on it. Would like it to be black to match the axles
- Town: South Africa
- Real Name: Craig
Too late I know, but they use silicon for the threads.Mud Dog wrote:Not sure if the dowel will work, Dylan ... it might, but it'll burn up in seconds. The local guys once told me what they do and it works .... I've never had issues. Can't remember what they do for the internal threads, but the external ones they just put some plain masking tape. Of course it burns away immediately, but the residue that it leaves on the threads is not removed by the surface flux in the dip tank and so the zinc doesn't coat them. The same principle is used for the internal threads ... damn! Wish I could remember what they told me.
- Gunta
- Real Name: Mark
What did the charge you do the galvanising?
- dustbuster
- Real Name: Dean
was just under R1300, I have to heat the galv. with a torch to make the galv soft and then tap the holes again luckily there are not to many on the chassis
That's the way, ah ah, i like it, ah ah...
Someone said it a few times here ..... without pics, it never happened!
- cheetah
- Vehicle: 1994 Hilux d/c 2.2
- Real Name: Anton
Dean keep us informed, we waiting for some more pices please.
Whot? are you guys blind. or blinded by the shiny chassis???
Blinded by lack of time to read far back enough.
