Starter Motor
- 2.8 d/cab SFA
- Town: Boksburg
- Vehicle: Yamaha R1
- Real Name: John
Starter Motor
i have to do starter motor again, I had it repaired then year later replaced it with a brand new one and the one year garentee expired last year. Now it doing the same thing again. Is there any service or maintanance you can do to give it a longer life?
John
Re: Starter Motor
What's the symptoms...2.8 d/cab SFA wrote: i have to do starter motor again, I had it repaired then year later replaced it with a brand new one and the one year garentee expired last year. Now it doing the same thing again. Is there any service or maintanance you can do to give it a longer life?
- 2.8 d/cab SFA
- Town: Boksburg
- Real Name: John
Re: Starter Motor
turn key just click, then in beginning if you bump it in gear then will start. Eventually that stop working also
John
- SWARTLUX
- Town: Gauteng
- Vehicle: '05 LEGEND 35 2.7 DC 4x4, Monroe Gas allround, Long range tank, UniQ Chip. Platkar '06 Polo 1.6 Comfortline hatchback
- Real Name: Brain
Re: Starter Motor
Sure its not your battery?Sound to me like the signs of a flat battery.2.8 d/cab SFA wrote:turn key just click, then in beginning if you bump it in gear then will start. Eventually that stop working also
Re: Starter Motor
Mine did the same. First though it was a dirty starter but after cleaning it did the same.2.8 d/cab SFA wrote:turn key just click, then in beginning if you bump it in gear then will start. Eventually that stop working also
Then I searched for the starter relay but it seems mine doesn't have one but if yours do there is a mod you can do to it to sort out the problem
Alternatively (what I did) is just add a relay where you used the lead to the starter to power a relay which supplies direct power from the battery to the starter. Worked like as charm for me
- The Legend
- Real Name: Dawie
- Club VHF Licence: X93-
Re: Starter Motor
Could be also the solinoid.
Re: Starter Motor
My dad's Nissan bakkie did the same (inherited from grandfather, only way it got into the family)
I cleaned the poles on the battery and the clamps and problem disappeared.
- The Legend
- Real Name: Dawie
Re: Starter Motor
Could also be an earth problem.Check all your earh cables to chassis and engine.
- 2.8 d/cab SFA
- Town: Boksburg
- Real Name: John
Re: Starter Motor
Thanks I have check all the earths, battery is not old replaced after starter last time, diesal battery
John
- Blaps
- Town: Rustenburg
- Vehicle: Hilux 4x4 Ford V6
- Real Name: Ben
Re: Starter Motor
What i did...... I took my stater out nineteen times over a period of two weeks, stripped it completely and cleaned it and checked the commutator on the armature, checked the brushes.... that were all good. I tested the solenoid and it was good. Checked the bendix and it was good. Put it together but still the same problem. I bought a new solenoid and bendix and replaced that but still the same problem. I tested all the windings, checked all the electrical connection points but the problem was still there. Eventually i took my jumper cables and Earthed the stater directly from the battery and it started every time. I then checked the earth wire to the engin and found that it got burned by the manifold I replaced and re-routed it and connect it to a different place on the engin and since then starts every time
Go, just go.... Somewhere.... Out There...
Re: Starter Motor
Must be what's wrong with mine as well. When I took it out and tested it on the test bench it worked like a charm but as soon as I fit it to the bakkie the problem started.
