My fridge slide
Sun May 06, 2012 9:50 pm
Had a bit of time on hand and decided to tackle my fridge slider. I have a lot of bits and pieces of material lying about, so decided to use what I have rather than buy unnecessarily. Pulled out 6 x 1 metre off-cuts of galvanised angle (40x40x3 so not too heavy), and cut to sizes. Welded up the carrier .... made it a little oversized because I was going to fit the runners with bolts and nuts and wanted to leave a little space around the fridge for the nuts as well as the thermal bag on the fridge.
Took one of the scrap off cuts and cut a latch out of it after measuring up and determining where the runner bolts would go. Drilled and welded in a threaded pivot pin and a 'hook' point for the spring, also cut and bent a stop. This all probably took up most of my time.
All I had to buy was the runners .... couldn't get the heavy duty alu ones in the length I required, so just got the steel ones that are rated at 45kg on full extension ..... a lot cheaper at only R50.30 incl. for both, so if they're not good enough I can always replace with the correct length alu later.
Anyway, it was only when I got to the point of fitting the runners that I realised I didn't have any nyloc nuts for that small size bolt (will have to get tomorrow), so in the meantime I just drilled the holes a little smaller and tapped threads into them as an interim solution.
Mounted the runners to the side rails and then to the carrier.
All that was left for now was to cut the groove for the latch to locate and I was done for today.
All the brown marks on the steel are just dirt, so I will have to give it a good clean-up before fitting into the van. To fit I will just use Tech-screws ... about four or five per side rail. Also have to still cold-galvanise all my welds, cuts and grinds. Of course I will also still have to make some kind of arrangement to secure the fridge ... for this I have a couple of canopy clips and will use them to make a couple of adjustable quick-release brackets.
Will post more pics when it's completed. ;-)
Sun May 06, 2012 10:05 pm
Nice and simple :thumbup:
Ali3n
Club VHF Licence: B338
Sun May 06, 2012 10:10 pm
I like... might work for me too... :think: :thumbup:
PRESENTLY DISADVANTAGED
Sun May 06, 2012 10:15 pm
What size fridge is this one for?
Sun May 06, 2012 10:27 pm
OOOOMS wrote:What size fridge is this one for?
45 lit / 65 lit Campmaster. The internal measurements of the carrier are 700 x 500mm
MOFASA
Real Name: Johno
Club VHF Licence: X119
Mon May 07, 2012 7:06 am
Very nice...... :thumbup:
How did you cut the latch..... It looks like its laser cut :?:
ImageImageImage[rimg=206x128]
jacques kotze
Town: Nelspruit
Vehicle: 2,8 4x4 Auto Fortuner. 2,8 4x4 Hilux singlecab.
Real Name: Jacques
Mon May 07, 2012 7:19 am
Nothing wrong with that :thumbup: :thumbup: :thumbup:
Royco
Town: Stellenbosch
Real Name: Roy
Club VHF Licence: X88
Mon May 07, 2012 7:57 am
Thanks for the post, Andy. :thumbup:
I'm about to start making my own slide and like your catch idea! Very clever :thumbup: :thumbup:
Image Image Image Image
Johannes van die See
Mon May 07, 2012 8:00 am
:thumbup:
Nice Andy!
http://www.goblacksam.com
Image Link Broken
Langebaan Lagoon & Deep Sea Fishing Charters
Mon May 07, 2012 8:52 am
MOFASA wrote:Very nice...... :thumbup:
You might be surprised at what can be achieved with a hack-saw and a file. :D:
Mon May 07, 2012 1:48 pm
I hope you made two while you were at it, Andy... ;)
Mon May 07, 2012 3:46 pm
Family_Dog wrote:I hope you made two while you were at it, Andy... ;)
Yes, one for the 45l and one for the 65l fridge..... :lol: :lol: :lol:
Mon May 07, 2012 5:14 pm
:laugh2: :laugh2: No, the 45 lit and 60 lit CampMaster units have the same base dimensions .... just the height varies. ;-)
Haboob
Town: King Williams Town
Real Name: Edge
Club VHF Licence: HC129
Mon May 07, 2012 7:15 pm
Well done Andy, when to we leave for the first outing to test the fridge ?
HABOOB means "Dust Storm"
Mon May 07, 2012 7:47 pm
Will have to make a plan soon, Edge (with or without the fridge) .... both me and the Lux are having withdrawal symptoms ... it's been almost a month since I engaged the short lever! ;-)
Aquanaut
Town: Durban
Vehicle: Hilux 3.0D4D
Real Name: Basil
Mon May 07, 2012 10:30 pm
Seeing that you have all this time on your hands, about one for m.......? :D:
Mon May 07, 2012 11:00 pm
Geez, I wish I had another 8 hours in every day ..... then I'd make for whoever wants. :laugh2: It's quite simple and inexpensive to make ..... actually 'Aunty' Val is going to try make one for herself, I believe! :D:
For now it's lying in the shop where I left it on Sunday .... haven't had a chance to get near it again yet .... might have to wait for the weekend again. :(
ROOFER
Town: grassy park cape town
Vehicle: 99 s/c hilux 4x4 2.7i long range tank & dual battery; 2003 nissan x-TRAIL (4X4)
Real Name: charl
Tue May 08, 2012 10:51 am
Very nice indeed :thumbup: :thumbup:
Tue May 08, 2012 4:35 pm
The 60l is bigger than the 45l, but the 45l will fit :thumbup:
60l - ·G.W./N.W.:27 KG/25 KG
·Dimensions 72cm (w) x 52.5cm (d) x 59.5cm (h)
45l - G.W./N.W.:23 KG/21 KG
Dimensions 69cm (w) x 49cm (d) x 47.5cm (h)
:lol: :lol: :lol:
Tue May 08, 2012 5:10 pm
I like your slide, straight forward and practical. That clip is a super good idea.
1999 Hilux 2.7i 4x4 Raider DC with 3.4 Prado V6. Rear diff-lock, Red Peppor Bull Bar and rock sliders, 31" Cooper ST, Snorkel, Alu-Canopy, VHF Motorolla radio, West Coast Rust, Mikem Rear Suspension, Ball Joint Spacers in front, 25watt LED Spots
Tue May 08, 2012 6:32 pm
Thanks for the compliments guys! ;-) Ja, simplicity has its advantages .... less work :shifty: .... and less to go wrong.
Mark, where did you get those measurements? Before cutting my material I checked my manual and it gave the base measurements as the same for the 60l I also checked my 45l base measurements physically just to be sure. :eh:
Tue May 08, 2012 7:29 pm
Mud Dog wrote:Thanks for the compliments guys! ;-) Ja, simplicity has its advantages .... less work :shifty: .... and less to go wrong.
Goooooogle'd it.
Wed Jun 20, 2012 3:27 am
Ok, just to finish this off, I dismantled the slide, cleaned up all the old steel, cold galvanised all my welds and grinds, painted it with 3 coats black oxide etch primer and assembled it again after letting it cure for a week or two.
Then I set about making up some clips .... again, kept it simple and used two canopy clips with a bolt welded to them and a pair of slightly modified 'J' hooks. This allows it to be adjustable to a small degree, allowing about 20mm adjustment.
(80.33 KiB) Downloaded 568 times
I then tested positions in the load bin for clearance and mounted it to the floor with tek-screws. Works just fine.
(62.41 KiB) Downloaded 568 times
(64.48 KiB) Downloaded 568 times
The only hassle I have is the power cable when sliding the fridge in and out .... it tends to get in the way when sliding the fridge back in, so I've just been keeping the cable nicely tucked in along the side and just disconnecting before sliding the fridge out / reconnecting after sliding in. A bit of a hassle but I assume that most may have experienced a similar problem .... any ideas? (Thought of sewing a couple of velcro loops to the side of the fridge cover to route the cable and keep it clear of the slide. :think: ).
The Legend
Real Name: Dawie
Club VHF Licence: X93-
Wed Jun 20, 2012 4:57 am
Very neat work Andy.Looks great :thumbup:
Wed Jun 20, 2012 5:01 am
Nice Andy, looks good :thumbup:
Yip, cable jamming is a concern with a slide, def. :!:
What I dis with mine, sleeved it with that black stuff from Mid@s. Attach the cable fairly high on the side of the fridge the with a something elastic, so that it pulls straight when the fridge is 'out'.
Willem01
Vehicle: het nie 1 nie
Real Name: Willem
Wed Jun 20, 2012 7:08 am
I have the 60L to get the cable out of the way I just fitted the fridge on the left hand side so that the fittings on the fridge where it plugs in is showing to the inside and extra baty is also on the left against the "wall" so only left 1m of the cable under the slide frame and have no hazzle with plugging in or out when sliding it out.
Bugzy
Town: Rustenburg
Vehicle: 2015 Hilux S/C 4X4 Dakar1996 2.8D s/c 4x4 Hilux with 3CT Toyota motor
Real Name: Buks
Club VHF Licence: X56
Wed Jun 20, 2012 7:46 am
Very nice Andy, I like the clips holding the fridge in place :thumbup: :thumbup:
