Fuel Tank Frustration
Cinco
Town: Marloth Park
Vehicle: Hilux Vigo
Real Name: Ian
Club VHF Licence: HC243
Post by Cinco »
It takes about 20 minutes to fill up with diesel on my D4D.
The nozzle on the fuel hose will not lock and so the fuel has to be leaked into the tank very slowly.
I have tried to get to the breather but cant as one would need to drop the tank.
Surely this is not normal?
Wishing my life away till the next trip!
Re: Fuel Tank Frustration
Post by OOOOMS »
Ian, do you have a long range tank fitted?
Post by CasKru »
Cinco wrote:It takes about 20 minutes to fill up with diesel on my D4D.
I had this happen to me once with a Verso I had. Would take about 15minutes to fill the tank. Toyota fits some sort of flap valve assembly at the point where the hose goes into the tank. This I'm guessing is to allow the flow of fuel into the tank but stops it from splashing up into the pipe whilst driving. This valve on the Verso got stuck. I just remove the feeder pipe and removed this device and problem was solved.
Maybe your van has a simular valve / device that does not the open anymore.
Post by CasKru »
This is the device I am talking about on the Verso. Maybe your bakkie has the same or similar thing
Cinco
Town: Marloth Park
Vehicle: Hilux Vigo
Real Name: Ian
Post by Cinco »
No, I don't have a long range tank.
I will check that flap as soon as possible.
:think:
Thank you!
karoodonkie
Town: Laingsburg
Vehicle: `81 Hilux
Real Name: Anthony
Post by karoodonkie »
AFAIK it is an "anti spit back valve". There for when filling up to prevent spit back as the tank reaches its max mark.As the fuel goes in and suddenly hits the pocket of air in the top part of the tank (ballon effect) and the fuel will go up the filler pipe and spills out. This is an big problem on Chrysler vehicles.
http://www.safetyresearch.net/.../fuel- ... tinues-to-.." onclick="window.open(this.href);return false;.
Post by pietpetoors »
Mine spits like that since I fitted the 2nd tank. Maybe I damaged that flap when I installed the extra pipe in the tank or maybe it is the 2nd tank that does the spitting.
Bulletjie-3
Vehicle: Hilux Raider SFA met 7M-GE engine
Real Name: Everdt
Post by Bulletjie-3 »
Cassie wil that valve not prevent evapourising ( spelling ?)of the fuel ?
Cinco
Town: Marloth Park
Vehicle: Hilux Vigo
Real Name: Ian
Post by Cinco »
I finally dropped my diesel tank and could find nothing wrong. I then checked inside the filler neck (pipe) and found a brass or copper sieve in the neck. Obviosly put there to prevent the siphoning out of diesel. Now I need to figure out how to strip out the filler neck so that I can remove the sieve.
SuidWes
Town: Durbanville
Vehicle: Prado 120 VX
Real Name: Jaco
Club VHF Licence: B35
Post by SuidWes »
Yip, sounds like an ASD - Anti Siphoning Device.... Did you buy new as these are usually fitted to fleet vehicles?
Also, what diesel are you using - Some add anti-foaming additives to reduce foaming which speeds up refuelling...
Cinco
Town: Marloth Park
Vehicle: Hilux Vigo
Real Name: Ian
Post by Cinco »
jaco
No, I bought second hand. I try and use 50ppm whenever possible (95% of the time).
SuidWes
Town: Durbanville
Real Name: Jaco
Post by SuidWes »
Cool, most brands have the additive - But some are better :)
Should not be too difficult to remove that ASD... Good luck!
Polarbear2008
Real Name: Theunis
Club VHF Licence: X49
Post by Polarbear2008 »
Do you know if there was ever a long range tank fitted? Mine had one (which was removed before the sale) and I had endless hassles, until I took it to Cris Ingram of R&D Offoad, who replaced and rerouted one of the pipes, and now I can refill it as fast as I want to.
Monroe Gas Magnum shocks
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
Cinco
Town: Marloth Park
Vehicle: Hilux Vigo
Real Name: Ian
Post by Cinco »
No I dont think a long range tank was ever fitted. I did phone my local Toyota dealer about it but the guy I spoke to did not know what I was talking about so I guess the sieve was a retrofit.
Cinco
Town: Marloth Park
Vehicle: Hilux Vigo
Real Name: Ian
Post by Cinco »
I finally fixed my problem after a groot vloek.
On the weekend I removed the offending sieve. It looks like the bottom plastic part of a jerry can filler attachment that broke off and fell into the diesel tank filler neck. That is why my own plastic extension is pop riveted to the attachment to prevent this from happening.
Jerry can Extension
Jerry can Extension
Tank Sieve 1 190812.jpg (32.82 KiB) Viewed 4031 times
Jerry can extension
Jerry can extension
Tank Sieve 2 190812.jpg (26.98 KiB) Viewed 4031 times
Thanks for all the assistance.
The Legend
Real Name: Dawie
Club VHF Licence: X93-
Post by The Legend »
Glad to hear your problemis is fix :thumbup:
ATH
Town: Durban
Vehicle: 2007 Toyota Hilux 2.5 D-4D SRX 4x4
Post by ATH »
Good perseverance and thanks for reporting on the fix.
Polarbear2008
Real Name: Theunis
What next! Glad it is fixed now!
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
