Beste olie vir kzte gearbox.
- 320busa
- Town: Springbok
- Vehicle: 1996 Toyota Hilux with Kzte engine.
- Real Name: Kosie
- Club VHF Licence: n/a
Wat sal julle voorstel is die beste tipe en graad olie vir n Kzte 4x4 gearbox?
Re: Beste olie vir kzte gearbox.
EP90
- george
- Town: Velddrif
- Vehicle: Triton 3.5l V6
- Club VHF Licence: HC107
- TJV
- Vehicle: 3.0 liter D4D Fortuner,, Roof rack and VHF radio
- Real Name: Theunis
- Club VHF Licence: X 110
Kosie
Het my Hilux ook op Castrol BOT 180 gesit en die warm reuk op lang pad was daarna weg. Maak net seker GL 4 / GL 5
- Polarbear2008
- Club VHF Licence: X49
Sal goed wees om te hoor wat HOPPY hier te se het? hy het onlangs my vooras herbou (KZ-TE) en het self die olie vervang. Ek wonder wat het daar ingegaan....? Ek vertrou hom either way!
Monroe Gas Magnum shocks
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
- Real Name: Marnus
Castrol BOT 130 het nou 'n nuwe naam. Castrol Syntrans Multivehicle. Presies dieselfde specs as BOT130. Dit is 'n volle sintetiese 75W-90 API GL4 olie
- Real Name: Marnus
Het die afgelope naweek die olie in my D4D se ratkas en oordra ratkas met Castrol Syntrans Multivehicle vervang en daar is 'n groot verbetering in hoe die ratte wissel. Ek kan dit definitief aanbeveel.
- ismail
- Real Name: Ismail
can that oil be used in a 2.7 box also?
I surf more than I work
- Real Name: Marnus
I'm quite certain that it can. I haven't seen the specs on the gearbox of the 2.7 but I'm almost 100% sure that it must be 75W 90 API GL4. Just check in your car manual. Remember that the Diff needs API GL5 i.e Castrol EPX 90 or similar. It does not appear as if Castrol makes a Synthetic Diff oil.
- ismail
- Real Name: Ismail
Thanks Marnus will check it out cause my bakkie is due for a service at the moment.
- Town: Lichtenburg
- Vehicle: 99 2.7 DC 4x4
- Real Name: Liaan
- Club VHF Licence: AC1
Ismail - the Bot 130 is great in the 2.7 gearbox!
Smooottthhhh shifts!
Other guys also swear by Caltex Easyshift - not availible in Lichtenburg though.
Almal kry die voorreg om onnosel te wees, net jammer party maak misbruik daarvan
99 2.7 Raider 4x4 D/c
OME and some more...
Gebore in die BLOU BUL hoofstad
- 320busa
- Town: Springbok
- Real Name: Kosie
Baie dankie aan almal se insette.
- ismail
- Real Name: Ismail
thanks for the info my side also, just put in my bakkie, gonna see how good it works.
- george
- Town: Velddrif
jip.GL 5 will corrode your syncronisers.GL4 for the box and GL5 for the diffs.I know some workshops use GL5 for the box and diffsMars wrote:I'm quite certain that it can. I haven't seen the specs on the gearbox of the 2.7 but I'm almost 100% sure that it must be 75W 90 API GL4. Just check in your car manual. Remember that the Diff needs API GL5 i.e Castrol EPX 90 or similar. It does not appear as if Castrol makes a Synthetic Diff oil.
- ismail
- Real Name: Ismail
Thanks George got that
