Yes Yes manne
ek wil net 'n vraag vra namens my vriend wat 'n Colt Clubcab ry
daai bakkie is biekie baie vrek swaar op glow plugs en die van is nie eers so oud nie ?
ek het darem i sfa en i stout so geen glow plug probleme vir my nie
het enige iemand raad asb
glow plugs
- WESKUSKLONG
- Town: St Helena bay
- Vehicle: Hilux KZTE with ARB front locker/Safari Snorkel / 33x12.5x15 tyres / Long range tank / Battery system / Thomas compressor/ 2Engel fridge freezers/Cruise Control.
- Real Name: Rudi
Re: glow plugs
Se hy moet wag vir die liggie om dood te gaan voor hy dit start, dit gee die glow plugs bietjie kans om af te koel voor die injectors diesel daarop spuit.
- Town: krugersdorp
- Vehicle: 1988 SFA 4x4
- Real Name: richard
Re: glow plugs
baie dankie
maar gaan dit die lewe van die glow plugs aansienlik verleng ?
:wth:
:wth:
- Oupa Stig
- Town: Johannesbug
- Vehicle: Hilux KZTE 4X2 "Stagger Lee", Hilux IFS 2.7 4x4 "Loretta"
- Real Name: Mickey
Re: glow plugs
Soos ek dit verstaan moet jy in elk geval wag vir daardie liggie om af te gaan - ek doen dit al van '2005 vir meer as 220k kilos, geen probleem. In fact, ek's so gewoond daaraan, ek wag selfs vir my vrou se Tazz se glowplugs....
- Town: somerset west
- Vehicle: toyota
- Real Name: jose
Re: glow plugs
Gebruik n NGK part no:Y701J glowplug. Dit hou baie langer .Op die Colt 2.8 kom die glowplugs weer aan na dat die engine gestart het,en bly aan vir omtrent twee munite.
- Town: krugersdorp
Re: glow plugs
baie dankie vir julle insette waardeur dit
- Rollercoaster639
- Town: Bethal MP
- Vehicle: Hilux 2.8 4x4 AT extended cab.
- Real Name: Barry
- Club VHF Licence: X84
Re: glow plugs
Guys I also have a colt 2.8 and I am also going through glow plugs. I do believe that part of my problem is that I am using the cheap and nasty replacement one. I did however use the OEM ones which are very expensive but did not notice a differance that warrented the extra hard earned cash.
I also believe that another factor that might have an effect is how cold it is and where the bakkie is parked. In my case I am in the Bethal district and the bakkie is parked outside and not in a garage. Very cold in winter and hard starting in the morning.
On the other side of the coin I have another diesel bakkie which is treated the same and I have never replaced the glow plugs. Will not mention the brand as I dont want this to become brand bashing
I will watch this thread
- Town: krugersdorp
Re: glow plugs
jahaaa
dit moet iets op die voertuig self wees wat die glow plugs eet ?
my hilux is nie so honger nie
