With reference to a topic I started a few days ago regarding chipping vs remapping on my Hilux I finally came up with a decision. As my bakkie is still under warranty I do not want to go the SAC route and hardwire a piggy-back system into her (playing it safe) and the remapping leaves a footprint on the ECU which should something go wrong is detectable. So I decided to go with the Chipbox.
However when I phoned in the sales guy there asked me to open the bonnet of my Hilux and tell him how many plugs were on the Performance module. I counted four. He told me that it was impossible as it should only have 2 or 3. So I sent him a photo and he told me he could not believe it. It is the first time he has ever seen a 2.5 with this module. Now I dont know much about this sort of thing.... Can someone please tell me what the performance module does and which one I have in my bakkie . Is it a 3.0 module.... or a Fortuner module??? I would have thought they would have used the same thing.
Any help would be appreciated. I have attached pics below.
performance module....
- Joffy
- Town: New Hanover
- Vehicle: Toyota Hilux 2.5 D/C 4x4 SRX One-of-a-kind Edition
- Real Name: Jonathan
- (118.82 KiB) Downloaded 144 times
- (112.55 KiB) Downloaded 144 times
Re: performance module....
You should compare it to the 2.5 fortuner - those should have the same goodies.
Ask for a 2.5 Fortuner chip.
But eish, I would not trust a generic chip in my truck. At least with SAC/Dastek it gets programmed for your vehicle on a proper dyna and all parameters are checked, eg EGT, boost, etc.
- AM Racing
- Real Name: Dylan
That is the injector driver.... Get a Plug and Play Unichip........ :!: No cutting at all, done plenty! With the map on it you are good for a +- 15% increase.
- Joffy
- Town: New Hanover
Injector driver.... Ok so then either the guy does not know what he is talking about or he asked me for the wrong part. What does the injector driver do?
- AM Racing
- Real Name: Dylan
Basically it takes the low voltage from the ecu and acts like a switching relay and switches the injectors on and off.
