hilux 4.0 auto 4x4 vibration
- Town: cape town
- Vehicle: hilux 4.0 4x4
- Real Name: david
Hi guys I feel vibration when decelerating from 60 down to 40 , its not tyres or wheel balancing I've had this checked , I only experianced this after fitting a level it kit in the front and new shocks , I have loosened the carrier for the cntre bearing and retightend it again but still the same , any thoughts ?
- Town: JHB
- Vehicle: Isuzu 3.0 D-tec
- Real Name: Darrell
Re: hilux 4.0 auto 4x4 vibration
Hi David.
How much did you raise the vehicle did you check the alignment after.
Jacques workshop 021 939 8688 is your best bet or Hoppy on the forum.
Who fitted it for you ?
Regards
Darrell
Mikem Suspensions
Regards
Darrell
Mikem Suspensions
- Town: cape town
- Real Name: david
Hi Darrell I think it was a 30 mm spacer gave me a 50mm front lift , the kit is made by WR offroad and yes they did alignment , supa quick Belville in cpt did it , it is not hectic vibration but I feel a difference.
