4.0 V6 Paranoia
Christian Kuun
Town: Stellenbosch
Vehicle: 2008 Tuna V6 4x4 Manual
Real Name: Christian Kuun
Wed Aug 27, 2014 9:59 am
I recently noticed two things on my 2008 4.0 V6 Fortuner:
The first being a vibration that may have always been there and that I just never noticed. When I hold the revs at 2500-3000, in neutral, that there is a vibration throughout the vehicle and you can feel it on the door and roof too from the outside. Almost as if it is missing. This goes away when you rev it higher in neutral or you drive it.
The other thing that has happened of late is that when the engine is warmed up properly, there is a clack-clack-clack sound. Something like a tappet/lifter/leaking exhaust gasket type of sound. This noise is absent when cold or warm and gets noisy when warmed up. My wife also asked me why it is making a noise the other day, so this is obviously new.
Is this normal or does anyone else have the same issue? I took it to a very well respected mechanic and he reckons just about all the V6's he works on sound and feel the same. He reckons because of the design of the valves seating and the factory rather giving more clearance, it should technically get quieter and not noisier. The bus goes like the stink and there is absolutely no difference in power or fuel consumption. The vehicle has not missed a service and has 110 000km on the clock.
Wynkop Kuun
O82 6l5 8lO5
Wed Aug 27, 2014 11:51 am
Dis 'n Toyota. Hou op bekommerd wees en ry die ding.
Op 'n ernstige nood. Wanneer laas is hy gediens? Soos die olie ouer word verlaag die viskositeit en jy begin die valve lifters hoor.
Blitzkrieg
Town: Glen Marais
Vehicle: 94 Hilux D/C V8 Lexus. 2009 LC Prado 4.0 V6
Real Name: Jaco
Wed Aug 27, 2014 12:26 pm
Ek ry die 4.0 V6 Prado met 112 000km op.
Geen vibrasie of geraas nie.
Christian Kuun
Town: Stellenbosch
Wed Aug 27, 2014 2:20 pm
2000km terug gediens..... :roll:
Wynkop Kuun
O82 6l5 8lO5
toyo v6
Town: gauteng
Vehicle: hilux 4x4 v6
Real Name: paul
Wed Aug 27, 2014 5:13 pm
Die geraas is bekend veral op die our modele maar die vibrasie is n nuwe een vir my.
Myne het nou so 210 000 op
2007 model Hilux
Sent from my GT-I9190 using Tapatalk
stumps
Town: Alberton
Vehicle: Toyota 4.0L D/C 4x4; Camil
Real Name: Marius
Club VHF Licence: X225
Thu Aug 28, 2014 2:02 pm
Myne is ook 2008 en Mufasa loop soos n droom
2008 Hilux 4.0L 4x4 (Mufasa)
Toyota 4.0L D/C 4x4; Camil suspesion, Long Range tank, Kilber snorkel
1Co 15:10
But by the grace of God I am what I am: and his grace which was bestowed upon me was not in vain;
http://www.sandriver.co.za" onclick="window.open(this.href);return false; http://www.travelconsortium.co.za" onclick="window.open(this.href);return false;
stumps
Town: Alberton
Real Name: Marius
Thu Aug 28, 2014 2:03 pm
Give me a call on 083 three four three 3401. Might have answer on vibration
1Co 15:10
Rebel 4x4
Town: Port Elizabeth
Vehicle: 2014 Suzuki Jimny Fully kitted with every extra you can imagine that is available for a Jimny
Real Name: Thomas
Thu Aug 28, 2014 6:27 pm
Klink of iemand 'n D4D in jou bakkie gesit het toe jy slaap.
Sent from my iPhone
Huismoeles
Town: Bellville
Vehicle: V8 Disco 1
Real Name: Dirk
Thu Aug 28, 2014 8:27 pm
Laat kyk na jou universals
Dit was die fibration op my tuna
Fri Aug 29, 2014 7:36 am
Rebel 4x4 wrote:Klink of iemand 'n D4D in jou bakkie gesit het toe jy slaap.
Kyk maar net na die petrol naaldjie - Jy sal nie twyfel nie! :lmao:
Fri Aug 29, 2014 7:40 am
Christian Kuun wrote:2000km terug gediens..... :roll:
Nee dis te vroeg. Die beste raad wat ek jou kan gee is om die bakkie te ry en te kyk of dit erger word met tyd of tot dat daar regtig 'n probleem sy kop uitsteek. Die alternatief is om nou op 'n eindelose en potensieële duur soektog te gaan tot jy iets kry. Miskien het een van die ander forum lede die antwoord.
Christian Kuun
Town: Stellenbosch
Fri Aug 29, 2014 8:48 am
Universals is al gedoen- nie dat dit die problem kan wees nie want die vibrasie is wanneer die bus doodstil staan, in neutral, en jy hou die revs tussen 2000 en 3000. Nie terwyl jy ry nie.
Wynkop Kuun
O82 6l5 8lO5
JamesC
Town: Potchefstroom
Vehicle: SRX 2.5 4x4 D/C
Real Name: James
Fri Aug 29, 2014 10:58 am
Engine mounting? Ek het nou een vervang, aan die linkerkant.
James Cameron
0834431879
