Gearbox oil for 2700i IFS
- ismail
- Real Name: Ismail
Hi guys could anyone advise me on the correct gearbox and transfer case gear oil, everyone seems to give me a different story.
Ismail
Ismail
I surf more than I work
- hendrik.earle
- Town: Potchefstroom
- Vehicle: Toyota Hilux 4.0 V6 d/c a/t, 60mm lift, steeltop canopy, Custom Bullbar, Custom roofrack, WHEELS:vacancy open for 35x12.5r15
- Real Name: Hendrik
Re: Gearbox oil for 2700i IFS
I buy all my oil from the dealers. I have an auto and the correct oil from Toyota is cheaper than Autozone or Midas.
We never really grow up, we only learn how to act in public.
I used Shell Spirax 80W90 for the diffs and gearbox about 5 years ago.
Still going strong.
Still going strong.
- Vehicle: 2.5 Hilux D4-D 2012
- Real Name: Joe
Howzit Ismail.........The correct Manual Transmission oil you looking for is 75W-90 and the transfer-case takes the same oil as the gearbox
- Real Name: Marnus
a Quick search will reveal a number of threads on gearbox oil. I used Castrol Syntrans Multivehicle in my 3lt D4D 4x4 for both the gearbox and transfer case. It is more expensive oil but is full synthetic and it has greatly improved the smoothness of gearshifts.
- george
- Town: Velddrif
- Vehicle: Triton 3.5l V6
- Club VHF Licence: HC107
Just check in your manual.I am pretty sure the gearbox take GL4. My truck is not with me at the moment so I cant make double sure (looooong diesel story )pietpetoors wrote:I used Shell Spirax 80W90 for the diffs and gearbox about 5 years ago.
Still going strong.
Here is some reading about the diffrence
http://www.widman.biz/uploads/Transaxle_oil.pdf
- ismail
- Real Name: Ismail
Thanks for all the replies, problem is my wifes bakkie, I replaced the oil with Castrol syntrans then the gearbox started to whine, prior to it, was very quiet,
but Im going to replace it just with std Toyota oil and see what happens.
- Real Name: Joe
The Toyota std oil is G475W-90 and the transfer case takes the same.....remember one thing about synthetic oil......once you use it,you can not switch to a different oil again ......the reason for your box making a noise,is that the oil is to thin......
- Town: Springs
- Vehicle: Hilux 2700i
- Club VHF Licence: HC262
The dealers also told me G475W-90 but they don't have it. They use 80W90 .Joe-Tech wrote:The Toyota std oil is G475W-90 and the transfer case takes the same.....remember one thing about synthetic oil......once you use it,you can not switch to a different oil again ......the reason for your box making a noise,is that the oil is to thin......
- ismail
- Real Name: Ismail
Hi Joe
Could you elaborate please "remember one thing about synthetic oil......once you use it,you can not switch to a different oil again"
- Real Name: Marnus
Castrol syntrans is also 75w-90 so it is the exact same viscosity as the prescribed Toyota oil. It is definitely not "thinner" than the Toyota oil. If you look in the car manual you will see that it meets or exceeds the Toyota specifications.
Synthetic oil and minersl oil should not be mixed. If you drain it completely and leave the plug out for a while until no oil drains out and refill it with mineral oil it will be fine.
Did you drive the bakkie from new? It could be that it was noisy and was filled with diff oil to hide the noise. It is very,very unlikely that the syntrans could have damaged the gearbox.
