Pressure build up in fuel tank
- Koppelaar
- Vehicle: 87 2.2 SC
Morning gents,
On hot days (which is most days here in Limpopo) there is a build up of pressure in the fuel tank of my 87 SFA petrol.
I'm sure it has been covered before but anyone help with what I have to look out for?
Many thanks
Many thanks
- Masekind
- Town: Lichtenburg
- Real Name: Drikus
Re: Pressure build up in fuel tank
Stoot hy petrol uit?
- Stef
- Vehicle: '98 LTD
- Real Name: Stefan
- Club VHF Licence: X107
Been discussed somewhere....you'll have to search I can't remember the topic, but it was fairly recent...
Have the same problem, breather hole in fuel cap etc all OK but still does it. Doesn't bother too much as I have an external pump for the EFi.
I just don't fill it up completely if the bakkie is not going to be driven for a few days....
- Koppelaar
Nee, klink net asof hy "fluit". Is daar 'n breather op die tank?Masekind wrote:Stoot hy petrol uit?
- Club VHF Licence: X93-
Yip daar is n breather op die tank.Het myne die ander dag vervang .Nogal nie goedkoop gewees nie.Maar myne stoot nog petrol by sy overflow uit as hy vol is op n warm dag. Petrol cab in petrol gewas-geen verbetering nie.Koppelaar wrote:Nee, klink net asof hy "fluit". Is daar 'n breather op die tank?Masekind wrote:Stoot hy petrol uit?
Het dit nooit vantevore gedoen ,eers nadat ek die ekstra petrol tank op gesit het.
- Koppelaar
Re: Pressure build up in fuel tank - replace breather?
Does anyone perhaps know where I can buy a new "breather valve" in Pretoria or Nylstroom? Cannot get one in Ellisras, not even from the stealers!
- Masekind
- Town: Lichtenburg
- Real Name: Drikus
Praat jy van die carbon filter?Koppelaar wrote:Does anyone perhaps know where I can buy a new "breather valve" in Pretoria or Nylstroom? Cannot get one in Ellisras, not even from the stealers!
- Koppelaar
Drikus, ek is nie seker of dit 'n carbon filter is of wat nie nie.
Soos ek verstaan:
Die breather is basies 'n plastiek one-way valve wat druk ontlas wat opbou in die petrol tank agv pertol dampe. Op die petrolcap is die vacuum-breaker wat sorg dat die tank nie inmekaar trek as dit afkoel nie.
Meeste landcruisers het ook sulke breathers op brandstof tenk.
Soos ek verstaan:
- Masekind
- Town: Lichtenburg
- Real Name: Drikus
Ek is maar dom met die -2005 modelle maar die vigo get n carbon filter wat die over pressure op die tank uitlaat wat van die petrol tank af kom
- 2015-02-20_134632.png (28.42 KiB) Viewed 2099 times
Ek het myne by die stealers gekoop vir R196.71 na afslag plus btw
Hy is gelys as valve check part nr T90917 10054
- Koppelaar
Op my 87 SFA 4x4 sit die breather pypie bo op die tank aan die regterkant, nie deel van die inlaatpyp nie. Sal die een waarna jy verwys werk op my bakkie?Lollie wrote:Ek het myne by die stealers gekoop vir R196.71 na afslag plus btw
- george
- Town: Velddrif
- Vehicle: Triton 3.5l V6
- Club VHF Licence: HC107
Myne en joune is een en dieselfde.Die pypie wat uit die valve kom is ook die overflow pyp wat op sy beurt weer deur n rubber grommet in die chassis plug.Koppelaar wrote:Op my 87 SFA 4x4 sit die breather pypie bo op die tank aan die regterkant, nie deel van die inlaatpyp nie. Sal die een waarna jy verwys werk op my bakkie?Lollie wrote:Ek het myne by die stealers gekoop vir R196.71 na afslag plus btw
- Koppelaar
Dankie Dawie, ek sal by die agente gaan kyk as ek weer in die stad kom.
- Haboob
- Town: King Williams Town
- Real Name: Edge
- Club VHF Licence: HC129
Remember that petrol expands in heat & evaporates.
With the extra petrol tank in you have double the amount of petrol with double the amount of expansion & evaporation.
The second tank should have its own breather pipe to assist in this evaporation...
HABOOB means "Dust Storm"
