Help please D4D 3.0 Hilux
BadboyGP
Town: Midrand
Vehicle: Hilux D4D3.0 Raider DC 4x2
Real Name: Dineshen
Post by BadboyGP »
My Hilux over the weekend decided it no longer wants to start. It just swings and dies after a second.
I have checked the following:
Filter clean
Water trap clean
All fuses -ok
What I have noticed is when the incoming fuel line is removed and motor is swung there is no fuel being pushed into the filter cartridge.
Please help
Sent from my iPhone 6 using Tapatalk
Masekind
Town: Lichtenburg
Vehicle: 2005 Hilux 4x4 v6, LR tank, ARB Bumper. (iJzer)
Real Name: Drikus
Re: Help please D4D 3.0 Hilux
Post by Masekind »
Is daar diesel in die tank :surrender: :surrender: :surrender: :surrender:
Aquanaut
Town: Durban
Vehicle: Hilux 3.0D4D
Real Name: Basil
Post by Aquanaut »
Diesel sludge, the greenish slimy stuff, blocks the pickup filter? That happened on my old 2.5 TD Ranger.
antlo69
Town: Pretoria North
Vehicle: Toyota Hilux 3.0 D-4D, leveling kit, 17" with A/T BFg's, sadly stil some Tupperware, wish list growing by the day
Real Name: Antonie
Post by antlo69 »
Diesel filter - start by removing the water trap plug on the bottom of the diesel filter housing.
"Must be a Toyota, must be a diesel and must run on BFG's"
BadboyGP
Town: Midrand
Real Name: Dineshen
Post by BadboyGP »
Masekind wrote:Is daar diesel in die tank :surrender: :surrender: :surrender: :surrender:
Lol yes
BadboyGP
Town: Midrand
Real Name: Dineshen
Post by BadboyGP »
antlo69 wrote:Diesel filter - start by removing the water trap plug on the bottom of the diesel filter housing.
Housing clean as a whistle
Die$eL
Town: Midrand
Real Name: Nishan
Post by Die$eL »
does it have a chip? If so, remove it and try
Real drivers use three pedals
BadboyGP
Town: Midrand
Real Name: Dineshen
Post by BadboyGP »
Die$eL wrote:does it have a chip? If so, remove it and try
No chip!
Got it towed to dealer. They suspect transponder.
BadboyGP
Town: Midrand
Real Name: Dineshen
Post by BadboyGP »
Ok so injector pump is stuffed! 14,k to replace. Will be done under cpa implied warranty as I just bought the vehicle.
Die$eL
Town: Midrand
Real Name: Nishan
Post by Die$eL »
sorry to hear
hope they pay up!
