2006 4.0 V6 battery light
- oxydog
- Real Name: Jarus
- Club VHF Licence: J67
Hi guys, been a while (like the new look).
My Vigo's battery light won't switch off - been like that for 3 days now (suspect alternator). Everything is running fine - starts easily etc. I have an appointment for its 190 000 km service on 5 November. Should I rather have someone look at it before then, or is it safe to wait?
Thanks,
J
Thanks,
J
Bees (Toy)
'98 Hilux 2.8D 4X4 D/Cab
• ARB Bullbar
• Safari Snorkel
• GearMax Rear Locker
• Front Runner bakkie slide
• 31" BFG KM2's
'06 Hilux 4.0 V6 4X4 D/Cab
• Level-it kit (Front)
• Custom integrated bullbar
• Custom replacement bumper
• Midas driving lights
• 31" BFG KM3's
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
- Town: Potchefstroom
- Vehicle: SRX 2.5 4x4 D/C
- Real Name: James
Re: 2006 4.0 V6 battery light
Can be a faulty alternator. With car running, see if there is any charge from alternator. Might be a diode.
James Cameron
0834431879
0834431879
Do you have a volt-meter ?
Is it still charging at about 13,8V ? If not you will run the battery low and get stuck at some point ....
- oxydog
- Real Name: Jarus
I will test it tonight and sommer put it on the Benton for good measure.
Bees (Toy)
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
- Mylux
- Town: Roodepoort
- Vehicle: 4.0L V6 Vigo 4x4
- Real Name: Greg
- Club VHF Licence: HC249
Just be careful that she does not go into limp mode. It happened to me on the highway nogal! The regulator packed up and the battery voltage dropped to the point where the limp mode kicked in.
- oxydog
- Real Name: Jarus
Thanks Greg, I'll be careful.
Bees (Toy)
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
- oxydog
- Real Name: Jarus
OK, so the multimeter test indicated that she is not charging at all. Will keep her on the Benton every night until the 5th when she goes in for her 190 000 km service. Should be OK?
Must say I'm considering to have the alternator checked by someone other than the agents - Simply from a cost perspective. Any comments on this welcome.
Bees (Toy)
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
Agente gaan in elk geval die alternator na 'n autoelectrician stuur - en 100% markup vra.
Soos reeds gese: Willie Meyer 083 263 4410. Behoort so R600-1000 te kos.
- oxydog
- Real Name: Jarus
Dankie Thabo, ek gaan hom onmiddelik 'n lui gee. Waar rond is hy?
Bees (Toy)
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
- oxydog
- Real Name: Jarus
Does anybody know whether the alternator for a Vigo 4.0 V6 is the same as that of the D4D?
Bees (Toy)
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
- oxydog
- Real Name: Jarus
Hijacking my own thread: While trying to open the closed unit in the fuse box (which I shouldn't have done), I accidentally broke off a piece of the transparent cover (That is the long closed unit that contains a number of fuses, like the alternator one for example). Can I replace just this cover? Where can I find one (except from the dealers)?
Bees (Toy)
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
Jarus bear with this one ...
The alternator for a standard motor differs from that of a turbo driven motor - at least there is an extra "item" on the back of the alternator of a turbo motor.
A standard motor use the vacuum of the inlet manifold to provide suction to the brake booster.
With a turbo engine the manifold is under positive pressure, thus no vacuum to assist the brakes.
In many cases a small vacuum pump is fitted to the back of the alternator to provide this vacuum.
The electrics may well be the same though.
- oxydog
- Real Name: Jarus
Thanks Chris. Reason I'm asking: The guy I phoned to fix it for me has one for a D4D in stock. If it's different, he'll have to order one.
Bees (Toy)
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
Please keep us posted.
Would be interesting to hear if the D4D unit fits and works on the petrol engine ....
I don't think they are the same. Toyodiy lists a different part number for the two and the D4D has a 70 Amp Alternator and the 4l V6 has a 80 Amp alternator.
- oxydog
- Real Name: Jarus
OK, so I went to someone closer to my house, so I won't get feedback from the original guy, but the people who refurbished mine say they are different.
Bees (Toy)
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
- Vehicle: Hilux V6 4.0
- Real Name: Shareef
Hi everyone
My alternator light on my 2007 hilux is also on. It happened once before a few months ago but then went off by itself again.
I have a dual battery system with a ctek dual 250. The main battery measures 13.8v when the vehicle is on and 12.6 when off. So I can't figure out why the alternator light is on?
Any ideas.
Any ideas.
- Town: Griffith
- Vehicle: 07 Hilux SR5
- Real Name: Luke
The light is only there to show that the reg/rec is working apparently, doesn't do a very good job tho! When the alternator in my 07 died I had no light come on just a god awful whining noise! I replaced pulleys and tensioners trying to get rid of the noise but turned out the alternator had a dead diode in the reg which made it whine. Strange thing was too it was still charging ok at operating temp. The alternator in the lux is utter rubbish! I was glad when mine died cos now I have an upgraded unit which pumps out 14.5v all day long!
