Advice needed on SFA 2.2 EFI
Bosfebok
Town: Roodekrans
Vehicle: 1995 Hilux Raider 2.2
Real Name: Otto
Club VHF Licence: X248
Post by Bosfebok »
Hi fellow Luxers
I need some help. Couple of years ago I went EFI, but with a turbo as well. I want to take the vehicle back to just an EFI because it is extremely heavy on juice.
The current EFI is a Gotech MFI-X system that is firing the injectors in batch mode (0) (all firing at the same time).
So the question is :
- Is this the right mode for a normal EFI conversion?
- Does the batch mode not make your car very heavy on juice...as I can tell you, my 2.2 is now a guzzler.
- If not Mode 0, then which mode?
- Do I need to get anything extra to be able to fire the injector individually and at the right time and sequence?
I have a Toyota EFI intake.
Anyone you can recommend on the West Rand to assist me?
Many thanks.
Otto
Otto X248
1995 Hilux Raider 2.2 EFI Turbo DC
Alucab Canopy with Kitchen and Recovery sections
National Luna Split Charge system and Dual Battery
80W solar panel and MPPT controller
20.5" LED BAR
5ton tow bar with recovery points
Nudge-M front bumper
80l Long Range Fuel Tank
90l Water Tank
Slide Drawer System
Safari Snorkel
Double Lockers - Toyota Electric selectable
Diff breathers
The worst anti hi-jack alarm system ever, SANJI!!
A bad day out is still better than a good day in!!
Borntofish
Town: Johannesburg
Vehicle: Hilux 86
Real Name: Werner
Re: Advice needed on SFA 2.2 EFI
Post by Borntofish »
Think you need to speak to Louis Zanoli on this forum. Member name 4x4Megaworld.
Stef
Vehicle: '98 LTD
Real Name: Stefan
Club VHF Licence: X107
Post by Stef »
As far as I know the Dictator also does batch firing... 2 injectors at a time which is what I'm running.
If possible go sequential although I doubt if that would have a significant effect on consumption.
Vlak vark
Town: Phalaborwa
Post by Vlak vark »
Hi Otto,did you look at dictator management?
The Legend
Real Name: Dawie
Club VHF Licence: X93-
Post by The Legend »
Borntofish wrote:Think you need to speak to Louis Zanoli on this forum. Member name 4x4Megaworld.
+1 Louis did my EFI conversion on my SFA.He will sort out your problem very quickly
Bosfebok
Town: Roodekrans
Real Name: Otto
Post by Bosfebok »
Thanks gents, will give him a call.
Otto X248
20.5" LED BAR
90l Water Tank
Slide Drawer System
Safari Snorkel
Diff breathers
Mr_B
Vehicle: Honda Jazz
Real Name: Bretton
Post by Mr_B »
Hi, batch firing is correct. You won't win anything with sequential injector firing. Sequential firing would require a much more accurate timing method like a crank timing sensor. The magnetic distributor based timing won't do.
IMHO, it's the turbo that's making it guzzle fuel!
Stef
Vehicle: '98 LTD
Real Name: Stefan
Post by Stef »
Vlak vark wrote:Hi Otto,did you look at dictator management?
I would rather go with Spitronics; can get far more accurate with the tuning. If I have money to burn I would swap out the Dictator in my current setup
I agree Stef, At this moment in time Spitronics is the more versatile ECU. However, it all rides on how that ECU is mapped, and that is the critical factor with all the different brands. Get the right guy to set it up and it could mean the difference between chalk and cheese. :winkx:
Bosfebok
Town: Roodekrans
Real Name: Otto
Post by Bosfebok »
Thanks gents, I have made contact with Louis.
Otto X248
20.5" LED BAR
90l Water Tank
Slide Drawer System
Safari Snorkel
Diff breathers
Stef
Vehicle: '98 LTD
Real Name: Stefan
Post by Stef »
Mud Dog wrote:I agree Stef, At this moment in time Spitronics is the more versatile ECU. However, it all rides on how that ECU is mapped, and that is the critical factor with all the different brands. Get the right guy to set it up and it could mean the difference between chalk and cheese. :winkx:
True...mine was done by Schalk so I'm sure it's as good as it can be, but the man himself said the rpm increments are finer on the Spitronics. I'm sure that if Dicktator decide to change the firmware to accommodate the same then for the EFi conversion on our 22R's it would be just as good.
