Good morning Guys & Gals .
What are your experience/advice on using pirate tie rod ends eg. Midas & goldwagen?
Any feedback would be mush appreciated - engels is maar moeilik
Hulix vigo tie rod end
- Berries
- Vehicle: Toyota Hilux 3L d4d 4x4
- Real Name: Bernard
Re: Hulix vigo tie rod end
Just to add to my many many questions
the squeak is coming from inside the boot (left side) and there is play on both left and right
what needs to be replaced? tie rond ends? and being not so clued up on parts the inner part thingy
- Obelix and Dogmatix
- Town: ROODEPOORT
- Real Name: Quentin
Okay the inner thing part you refer to i believe is the steering rack.
pirate tie- rods, just put one into Obelix about four weeks ago and then gave obelix a major work out. no issues.
I went pirate as the lead time was to much from Toyota, and the pirate part was readily available.
God made man before
woman so as to give him time
to think of an answer
for her first question.
God made man before
- Rigger
- Town: George
- Vehicle: Toyota Hilux 3.0 S/C 4x4
- Real Name: Martiens
The inner part that the tie rod screws into is called the rack end. The rack end srews into the steering rack shaft.
- Town: Roodepoort
- Vehicle: Isuzu KB320
- Real Name: Garreth
Teknorot make good quality aftermarket stuff....
