2001 ifs HUGE power steering leak.
- Polarbear2008
- Real Name: Theunis
- Club VHF Licence: X49
I am puzzled. My 2001 ifs KZTE is losing power steering fluid at an alarming rate. I have looked everywhere along the pump and pipes but cannot seem to find the cause.
Leaving a sheet of paper under the truck overnight reveals a wet patch the size of a side plate! I understand that paper will make the patch took bigger but there should be nothing.
I would appreciate any help here greatly.
Sent from my SM-G925F using Tapatalk
Monroe Gas Magnum shocks
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
Re: 2001 ifs HUGE power steering leak.
On which side?
- Polarbear2008
Looking at the nose of the bakkie, the oil drip sits on the right rear nut of the bash plate. There is also a drip visible on the rear of the power steering pump.Thabogrobler wrote:On which side?
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
Sounds like the shaft seal on the pump is leaking. You'd have to clean it off properly and then check where the ATF actually weeps from.
- Polarbear2008
Mud dog I did just that and it seems to be appearing from the rear of the pump (the side that faces the firewall). There are no other possible places to he leak could come from.
Now next question: can one recon the seals or is it mega money replacement time?
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
The pumps can be re-conned - much cheaper than replacement. I would just first make sure that it's not one of the hose / pipe connectors that's leaking - Had that problem before.
- Polarbear2008
Thanks Mud dog. Now finding someone worthwhile to do the job in CT....Mud Dog wrote:The pumps can be re-conned - much cheaper than replacement. I would just first make sure that it's not one of the hose / pipe connectors that's leaking - Had that problem before.
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
- Polarbear2008
Feedback: found a CT company called POWER STEERING SOLUTIONS. Very professional service. Collected my Hilux at 8.15 and was emailed final invoice for payment around 12 same day! Had hilux delivered back to me by 2pm! All without having to phone or shout or anything?? Was very impressed!
http://www.powersteeringsolutions.co.za/
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
- louis fourie
- Club VHF Licence: X101
Cost?
Sent from my SM-G900F using Tapatalk
- Polarbear2008
R4300 for a new pump installed. Gone is the leaks.louis fourie wrote:Cost?
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
- Town: grassy park cape town
- Vehicle: 99 s/c hilux 4x4 2.7i long range tank & dual battery; 2003 nissan x-TRAIL (4X4)
- Real Name: charl
what was wrong with the pump could it not be repaired ?
- Polarbear2008
Not sure. Seeing as the vehicle has not had one in 265k kms I opted to replace.ROOFER wrote:what was wrong with the pump could it not be repaired ?
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
