Kzte cuts out on deceleration
AJTrees
Town: Pietermaritzburg
Vehicle: 2001 kzte Hilux 4x4 d/c
Real Name: Andrew
Post by AJTrees »
Hi
I own a kzte 2001 3.0l diesel it's done almost 500k on the clock. It's started cutting out while driving but it only occurres once during a during a driving session and usually on decelerating, i.e. Coming to stop, foot of the gas. I've suspect acsensor plug or sorts and have checked many I thought it might be the one on the turbo intake but that's seems to be fine.
Any suggestions
Tx Andrew
Polarbear2008
Real Name: Theunis
Club VHF Licence: X49
Re: Kzte cuts out on deceleration
Post by Polarbear2008 »
Look at all the plugs around the diesel pump. It is possibly a lose connection or worn cable around there. At least that is where I would start as the ecu has a hand in the running of the diesel pump on the kz.
Sent from my SM-G925F using Tapatalk
Monroe Gas Magnum shocks
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
