Rattle on front wheel
demond1
Town: Port Elizabeth
Vehicle: Hilux 2.5 D4D SRX
Real Name: Dean
Mon Oct 30, 2017 9:12 am
Hi Guys.
I've had to mothball my Lux :cry:
I've had it for about 3 months now. In the last 6 weeks, I've become aware of a vibration/grinding noise at high speed. It seems to be on the front right wheel. It only happens under very specific conditions, which are:
Traveling over 100km/p
about at 10-15 degree turn on the steering wheel
Only turning to the right. Turning to the left is perfect
This is what I have done so far:
Had it stripped down to the CV's which where found to be in perfect condition.
Replaced the prop shaft (which had bad UJ's)
Wheels have been balanced and aligned.
It seems to be becoming more and more pronounced. To the point where I wont drive it again, until this is solved.
Any advice would be much appreciated. Also, if anyone has had good experience with a workshop in the PE area, any referrals would be great.
pampoen
Town: Gordons Bay
Vehicle: 1997 Toyota Hilux 4x4 DC 22R, OME Suspension
Real Name: Luke
Mon Oct 30, 2017 11:54 am
Wheel bearings? Perhaps just jack the vehicle up and check the play also take time to look at all the steering joints etc. You may find the source of the problem.
Borntofish
Town: Johannesburg
Vehicle: Hilux 86
Real Name: Werner
Tue Oct 31, 2017 11:24 am
Do you have the anti Rattle clips on your brake shoes?
demond1
Real Name: Dean
Wed Nov 01, 2017 7:25 am
Checked the wheel bearings... no problems there.
As an experiment, I replicated the issue... only this time in 4x4 mode. Seemed to be gone. Put it back in 4x2, and it was back again.
Wed Nov 01, 2017 2:52 pm
Strange that it should go away when 4X4 is engaged. Is the ADD engaging / disengaging properly?
Punishing_Steel
Town: Kempton park
Vehicle: Toyota Hilux, 3.0 4x4
Real Name: Jan
Wed Nov 08, 2017 5:36 pm
Check this sway bar... drove me crazy for a month... just needed to be tightened... pic below.
Image Link Broken
demond1
Real Name: Dean
Mon Feb 05, 2018 10:15 am
After much time and effort... problem solved. Ended up being the universal on the front prop shaft. Thanks for the suggestions
Rebel 4x4
Vehicle: 2014 Suzuki Jimny Fully kitted with every extra you can imagine that is available for a Jimny
Real Name: Thomas
Mon Feb 05, 2018 10:24 am
I am going to ask a real dumb question, isn't the front prop stationary when is 4x2?
Sent from my iPhone
Farmerbrown
Town: Mooi River KZN
Vehicle: 96 SFA D/C 4x4 2.4
Real Name: Malcolm
Mon Feb 05, 2018 11:36 am
To my knowledge , It will still spin as it is still connected to the wheels , But not engaged in transfer box . I could be wrong.
2.4 1996 SFA D/C
2.5 2015 hardbody 4x4 S/C
2013 Everest 4x2
2.5 2012 AWD Kuga(SOLD)
yz250 2 stroke
tw 200 farm bike
Lorry
Town: durban
Vehicle: D4D hilux DC $X$
Real Name: Lorenzo
Mon Feb 05, 2018 12:55 pm
hi.
on the older 4x4 with manual locking hubs , with the hubs unlocked and in 4x2 the front props are stationary.
on the newer models, there are no manual hubs so the front props are always turning, the 4x4 system disengages by means of a clutch. so in 4x2 the front props rotate.
Mon Feb 05, 2018 1:17 pm
hi.
I think you meant "front side shafts". :winkx:
LouisZ
Mon Feb 05, 2018 7:38 pm
The front prop turns, the side shafts not. :thumbup:
Tue Feb 06, 2018 8:17 am
Thanks for the feedback. Good to know.
Lorry
Town: durban
Real Name: Lorenzo
Tue Feb 06, 2018 8:46 am
my bad :)
