2012 hilux d4d power steering fluid
rigardt
Town: Alberton
Vehicle: 2012 DC Hilux D4D
Real Name: Rigardt
Club VHF Licence: HC348
Fri Nov 03, 2017 6:50 pm
i need to top up my steering fluid. is it a specific Toyota product or can I just get any fluid from a spares shop and top up ?
Sat Nov 04, 2017 7:29 am
You can get from Toyota, otherwise just use a decent grade ATF from a service station or spares outlet.
pieta.swanepoel
Vehicle: Toyota Hilux SRX 2.5D-4D 4x4 SC
Real Name: Pieta
Mon Nov 06, 2017 9:32 am
The Toyota spec is ATF Dexron III
dalkill
Town: Cape TOwn
Vehicle: 2007 3.0 d4d DC 4x4
Real Name: Shaakir
Mon Nov 06, 2017 2:58 pm
never checked my steering fluid level.
is it something that needs to be topped up once in a while?
TOYOTA IS MY LEWE
Mon Nov 06, 2017 4:50 pm
Should be checked. If no leaks, then no filling required. I don't think the ATF works as hard or as hot in a steering pump as it does in a gearbox, so it shouldn't be necessary to replace it either. Should be a clear bright red colour, if opaque or brownish colour then drain and replace. There are no drain plugs so you would have to loosen a hose, preferably on the low pressure side of the box, and nip it back cleaned and carefully once drained - also check that it's not leaking afterwards.
rigardt
Town: Alberton
Real Name: Rigardt
Mon Nov 06, 2017 7:37 pm
I bought a bottle of Castrol dexon II this weekend. haven't filled my power steering yet. reason I bought it is my power steering whines when the vehicle is cold. when its hot its quiet. had someone turn the steering wheel while idling when the vehicle was cold and the fluid drops below the low level. I don't see any leaks. never had this whine before. its a new thing so will see if the top up fixes the whining otherwise will probably have to take it in to Toyota.
Mon Nov 06, 2017 10:50 pm
That whine is typical of fluid being low. It expands as it warms up so the volume is increased and the whine stops. I'm sure that a top up will sort the problem - there are two "Full" marks on the dip stick, one marked "Cold" and the other "Hot", fill it cold and check it again when hot. A little overfull when hot is not a problem as long as it's just a little over the mark. :winkx:
Tue Nov 07, 2017 6:46 am
Yes I agree. The whining should stop once topped up. If there are no leaks the system will not need topping up. You are probably starting to get some minor leaks on the steering rack. If it keeps on doing it then top it up with Wynns Power Steering stop leak. Just keep on topping up till the leaking stops.
pieta.swanepoel
Real Name: Pieta
Tue Nov 07, 2017 7:58 am
The D4D has a filling container with marks for cold (low, high) and hot (low, high). Very convenient.
