Hi all,
My 1987 Hilux is reaching 300 000 km's and is due for a major service. I was wondering if anyone can recommend a good old school mechanic in George/Mossel bay/Oudsthoorn area?
Thanks in advance!
SFA Hilux Mechanic
Hi and welcome Joseph!
Hopefully the guys down your way can recommend someone, but if you're a mechanically minded DIY type, you can do it all yourself.
- Town: Ladismith
- Vehicle: 1987 Toyota Hilux 2.2
- Real Name: Joseph
Thanks for the fast reply Mud Dog!
My biggest concern is the timing and tuning mainly (Mostly certain that the timing is currently out on the bakkie). I can do mostly all the basics (oil,plugs ect).If I want to delve further, is there someone on the forum who can walk me through all the steps of doing a major service?
I'm pretty sure we can help. Things you will have to look at are of course as you mentioned, oil + filter change and plugs. The 4Y doesn't chew plugs so if you've replaced them recently it may not be necessary, but pull them out anyway to check them (be careful not to damage the aluminium sleeves and their seals - if you replace the plugs cut the washers off before fitting, they damage the sleeve and then you get oil leaks).
The other stuff is things like air cleaner element change, check brake fluid, hydraulic clutch fluid (these may be in need of replacement as the fluid is hygroscopic and becomes less effective if it has absorbed moisture). Remove wheels and check brake pads / shoes, grease the universals and slip joints, grease swivel hubs, check diff, gearbox and X-fer case oil levels (no need to replace these unless they are milky / opaque from water ingress).
On the motor you need to check all hoses, especially vacuum lines, that they are not perished / cracked and sucking air, Check that the float level is still in the middle of the sight glass on the side of the carb (No adjustment on the carb). And then of course it's the timing, points and condenser might need replacement, the chain and tensioner may need replacement if it's noisy. Fuel filter should also be replaced and plug leads checked for perishing / cracks of the insulation.
It sounds like a bigger task than it is, but if you take it one step at a time you will get there. The beauty of doing it yourself is not just the $ you save now and further down the line, but also to get to know your vehicle better and to put you in stead to be able to do a field repair if required in your travels.
Have fun.
Have fun.
- Rigger
- Town: George
- Vehicle: Toyota Hilux 3.0 S/C 4x4
- Real Name: Martiens
You can contact me at 0823197730 or visit my workshop at 8 Diamant street, George Industria. BJM Auto Services. Or pm me your number and I will call you back.
Regards
Martiens Bekker
Regards
Martiens Bekker
- Town: Ladismith
- Real Name: Joseph
Thanks for all the valuable info Mud Dog! I'm still deciding, but I think I'm strongly leaning towards doing it myself. At the same time it is a daunting thought, like you said if I do one thing at a time it cant be that bad. Also the positives greatly outweigh all the negatives by doing it yourself. Will it be all right if I pm you every know and then, if I find myself struggling with something? Thanks Martiens, I will definitely consider contacting you as well, the more help the better!
Thanks again everyone!
- Rigger
- Town: George
You are welcome to give me a call anytime if you get stuck with something. Or keep us up to date on this thread.
When you are in George come and say hi at my shop. I also do 4x4 accessories and building of aluminium canopies etc.
Rather than PM me, it would be better to post any questions here. More heads are better than one ...... and contrary to popular belief I don't know everything
But yes, always ask and someone will help ..... good way to learn.
