Calling all Sparkies - wiper issue
gotalovethebush
Town: johannesburg
Vehicle: Hilux VIGO 2.5 D4D SRX 4x4.
Real Name: Peter
Wed Aug 15, 2018 11:27 am
Hi guys.
Hilux Vigo D4D 2006
My fuse all of a sarden blew for my wipers. It only blew under load - when windscreen was dry.
I opened the cover and I can easily stop the motor by hand...
I have another hilux and swopped the whole wiper assembly into the other bakkie. It worked like a charm and I could never stop it.
So seems my bakkie is not giving enough current? As the wiper assembly does work in another hilux..
Any ideas what can cause a low current delivery?
Appreciate your help
Peter
Sent from my SM-G950F using Tapatalk
Wed Aug 15, 2018 11:48 am
The problem is almost guaranteed to be the wiper shaft bushes that are dry / dirty / corroded and have become stiff. This puts a considerable load on the motor. Just take some WD40 or Q20 and spray it onto the wiper shafts where the wiper arms connect. Lift the little cups first and try get the spray on the shafts where they exit the bushes.
Repeat 2 or 3 times at about 30sec intervals and try your wipers again. :winkx:
gotalovethebush
Town: johannesburg
Real Name: Peter
Wed Aug 15, 2018 2:47 pm
But the whole wiper assembly works fine on another vehicle which tells me the wipers are fine and it's the power being supplied that is the issue?
Wed Aug 15, 2018 4:09 pm
When you say "the whole wiper assembly" did that include the shafts that the wipers are attached to?
Wed Aug 15, 2018 4:18 pm
I'm referring to the shafts under these caps .........
gotalovethebush
Town: johannesburg
Real Name: Peter
Wed Aug 15, 2018 8:53 pm
Wiper assembly as per pic below...
Works in another hilux but slow and weak in mine Image
Thu Aug 16, 2018 12:02 am
OK then, maybe you have an electrical problem. Most likely a voltage drop of sorts, and this could be caused by a poor connection somewhere like corroded terminals on a connector or a dry joint on a soldered connection, even perhaps burnt contacts in the wiper relay itself. Not too sure where this relay will be situated in your model, but usually under the dash or behind a kick-panel - could even be in the fuse box in the engine compartment. You might be able to locate it by listening for it's click sound when the wipers are turned on and off.
Another possibility (a little less probable but not impossible) is that there is power leaking from the circuit, like a damaged or pinched wire.
Either way it's going to be a bugger to find and I would start by locating and replacing the relay. Good luck. :winkx:
Thu Aug 16, 2018 6:28 am
+1 on the relay. I have found in most instances that an electrical fault is actually a mechanical fault i.e. broken wire, damaged wire, loose/corroded connection or in the case of a relay which is an electro/mecahnical device burnt or corroded contacts.
Hope you come right.
gotalovethebush
Town: johannesburg
Real Name: Peter
Thu Aug 16, 2018 1:48 pm
Anyone know where the wiper relay is located?
