Transfer Box "Clank" on G52 5 Speed Gearbox
Zatopec
Town: Strand
Vehicle: 82 Hilux 4x4 S/C
Real Name: Rodney
Wed Aug 15, 2018 2:14 pm
Hello All
Looking at the picture, holding both ends of the input and rear prop shaft side output shafts and turning them in opposite directions there is lots of play and what feels like jumping or skipping a spline. something is loose/worn out inside and its not good. I noticed this when the transfer box was still bolted to the gearbox and turning the flange in any direction
I thought it was the rear prop shaft output side flange splines that was worn out so I removed it. Using 2 vise grips I found the same play/ clank or skipping of splines so I can safely eliminate the flange as the problem. I am not a fundi on this type of stuff and was hoping one of you guys came across or know of something like this.
I am on a tight budged, if someone can help me to diagnose the problem it will be a huge help and I am sure I will be able to fix it myself....
pampoen
Town: Gordons Bay
Real Name: Luke
Wed Aug 15, 2018 2:42 pm
You sound like you know what you are doing. Open it up and take a look. It already doesn't work so whats to lose? I know the transfer part is fairly simple in theory, perhaps in reality it isn't but common sense should get you over most obstacles.
Zatopec
Town: Strand
Real Name: Rodney
Wed Aug 15, 2018 2:55 pm
I am going to have to open it up eventually - I am actually hoping someone had a similar issue. Any advice will make it a lot easier...
Do you perhaps know where i can find a parts diagram/internal outlay of the components inside the TB
Tim86
Real Name: Tim
Wed Aug 15, 2018 3:23 pm
Zatopec
Town: Strand
Real Name: Rodney
Wed Aug 15, 2018 8:52 pm
Thanks Tim. This is going to be most helpful. Image
mcw
Town: krugersdorp
Vehicle: Prado 90 V6 3.4 Auto
Real Name: Martin
Club VHF Licence: X100
Wed Aug 15, 2018 10:30 pm
Hi Rodney
those G52 gearboxes are prone to breaking a tooth on the fifth gear ,mine did it ,do not khow if that is causing the noise on yours
Engines for Africa in Selby ,sell the gearboxes ,they may have T/cases ,3 years ago gearbox brand new was R5500.00
Martin
Thu Aug 16, 2018 12:21 am
Those old X-fer boxes did develop a bit of free play as they got older .... just normal wear and tear I guess. Pretty sure it can be reconditioned, but if it's not too bad I would just leave it and live with it.
