How to clean a radiator??
- Tim86
- Real Name: Tim
Just bought 600 bucks worth of Toyota coolant, ran some radiator flush through, tested thermostat, flushed system with water and then had a look down the radi through the cap and saw that many of the vertical tube openings are completely blocked! Had to prise out bits of calcium and sludge to open the ones I could get to. My new coolant aint goin in there!
Can anyone advise on how to clean all the gunk out? I will take the radi out, flip it and flush but is there any chemical I should soak it in to dissolve the sludge and calcium such as vinegar or caustic soda/sodium hydroxide? SFA radiator so copper and solder.
Thanks!
Thanks!
Re: How to clean a radiator??
Never had to go further than radiator flush, but if that's not doing it then IMO caustic is not the way to go - besides being highly corrosive it's a powerful alkali and AFAIK so is calcification. I reckon that an acid would break down the calcification but it's also corrosive and will probably attack the solder joints.
How long did you leave the flush in for?
- Tim86
- Real Name: Tim
I left it in for 3 days, drove 12kms, got motor up to operating temp twice. Slightly longer than the Wynn's bottle instructions in all cases. Prior to flush the coolant had a slight green tinge, after flush and when drained the coolant was proper dark khaki / rust orange coloured so the flush definitely helped, just not enough to remove the more solid, gunky bits. Like clay with quartz pieces in;)
- Real Name: Marnus
I would take the radiator in to one of those radiator services places. They know what they are doing and if they stuff it up then you have some recourse.
- Town: MISGUND WESTERN CAPE
- Vehicle: 1993 2.4d Hilux 4x4 SC
- Real Name: BAREND
Wynn's do a good job. I would give it a second dose and drive for longer than just 12 kilos. Drive around so that the engine can heat up properly. You can drive for at least 100 kilos. Coke also do a good job. Fill radiator with coke and leave a in for at least 12 hours then flush a few times. Remove thermostat and connect a hose to bottom hose of engine and let water run from bottom to top off engine. Do the same with radiator. Flush until water is as clean as tap water.
Just note that while coke might work, it's acidic and full of sugar. I wouldn't run it at operating temp too long with coke for fear of glazing from the syrup and sugar.
Tend to agree with Marnus .... take it to a radiator shop to be cleaned safely .... maybe they use an ultrasonic bath.
- Tim86
- Real Name: Tim
Yes Wynn's does seem to, these chunks may take a bit more time to dissolve so will give it another go as you recommend (flush and pure water for a few km's shouldn't hurt..?) - wasn't sure if leaving it in too long may cause damage so drained it after only a few km's. Will do the bottom to top motor water flush. Also will swing by Radiator King here in CT and see what they have to say although still want to do the cleaning myself. A google search reports flush active ingredients to predominantly be sodium citrate or phosphoric acid, which is also in coke. I'll give the coke a go with the radiator out.
Thanks for the advice.
- Dirka
- Town: Doornpoort Pretoria
- Real Name: Dirk
I agree with Andy on the sugar base in coke.
I'd rather go with (white) vinegar.
It's not strong enough to damage the metal but it does do a number on scale.
- dalkill
- Town: Cape TOwn
- Vehicle: 2.4 GD6 SR D/C 4x4
- Real Name: Shaakir
Just a quick sideline question... what does one do with the flushed out coolant.
recently there was an article where there was green antifreeze looking liquid flowing directly in the ocean here in cape town.
Since it is reported there does not seem to be any treatment before going into the ocean on atlantic seaboard side, and i live quite close to that area, i'm afraid flushing down drain at my house will end up going direct into the ocean... killing all the fishies i love to catch :-(
TOYOTA IS MY LEWE
TOYOTA IS MY LEWE
Good question. Read here bottom of pg7 and top of pg8 ... http://www.who.int/ipcs/publications/ci ... icad22.pdf
It doesn't appear to be readily biodegradable but bacteria in pond scum and sewerage achieve total degradation in 2 weeks. If the sewerage flows directly to the ocean, it's going to get there long before the day is out, but in most cases it will pass through some kind of sewerage plant before then after which time I suspect that it will be mostly broken down.
So as strange (I was going to say "fishy") as it sounds, it will appear that the best is to flush it rather than to allow soil contamination.
- pietdevs
- Town: Mosselbay
Try white vinegar. It cleaned my radiator perfectly. Leave it in for about 24 hrs and shake it if possible. Does the job well.
I have also done the vinegar trick. Works well but I might be OCD regarding cleaning.
I flushed the rad, did the vinegar and then removed the radiator and gave it a flush/soak with a acidic alu cleaner in and out. Now it is as clean as I like it.
- Tim86
- Real Name: Tim
Filled the radiator with vinegar, blocked the openings and pickled it for two days whilst turning infrequently. Put all back together and filled system with tap water and Wynn's flush only and drove for about 150km's. This is what really seemed to do the trick. When draining, the originally clear water and flush mix was a dark, rusty brown. Upon removal and flushing of the radiator, it was evident that the flush had partially dissolved some solids as there was quite a lot of new sludge that had settled to the bottom of the radiator.
