Seal kit for powersteering pump?
Baasvark
Town: Virginia
Real Name: Shane
Post by Baasvark »
Seems like my seals are shot! '95 22R.
Oil all over the place....
Is there a seal kit available? If not, what are my options?
Sent from my SM-A720F using Tapatalk
The Legend
Real Name: Dawie
Club VHF Licence: X93-
Re: Seal kit for powersteering pump?
Post by The Legend »
Gooi 3 proppies engine prolong (te koop by Veri Mart) by jou power steering pomp olie.Dit laat die seels uitsit en dan lek hy nie meer nie. Almal vir wie ek die raad gegee het , het terug gekom na my toe en dankie gese.Hulle powersteering pomp lek nie meer olie nie.
Baasvark
Town: Virginia
Real Name: Shane
Post by Baasvark »
The Legend wrote:Gooi 3 proppies engine prolong (te koop by Veri Mart) by jou power steering pomp olie.Dit laat die seels uitsit en dan lek hy nie meer nie. Almal vir wie ek die raad gegee het , het terug gekom na my toe en dankie gese.Hulle powersteering pomp lek nie meer olie nie.
Dankie!!!
Gaan dit virseker probeer!!!
niclemaitre
Town: Stellenbosch
Vehicle: 99 IFS DC 4x4
Real Name: Nic
Post by niclemaitre »
Is it the pump that's leaking? Or the banjo fitting on the high pressure side? That's just 2 O-rings to replace
If you take the pump to any hydraulic place they should be able to sort it for you.
Happy trails
Nic
SFA '87 DC "Rooies" - sold
IFS '99 DC "Benny"
pietdevs
Town: Mosselbay
Vehicle: Toyota Land Cruiser Troopy
Post by pietdevs »
Remove the pump and replace the O-ring. Very simple to do. Buy the O-ring from any shop that sells seals etc. I paid R4 for the O-ring and problem solved. It is just a miserable job to take the pump out and to put it back. Pity I did not know about the Pro-long fix!
niclemaitre
Town: Stellenbosch
Real Name: Nic
It's not difficult to get the pump off - only took me a couple of hours because I couldn't get the pulley off so had to cut the bolt in half...
Happy trails
Nic
IFS '99 DC "Benny"
Baasvark
Town: Virginia
Real Name: Shane
Post by Baasvark »
Ok thanks guys! Did the prolong test and seems to be working for now.
This should hold till the first opportunity I get to properly strip and see where the problem is coming from and to get the necessary o- rings!
Thanks again!
The Legend
Real Name: Dawie
Baasvark wrote: Thu Sep 13, 2018 8:55 pm Ok thanks guys! Did the prolong test and seems to be working for now.
Thanks again!Image
Pleasure Shane :thumbup:
