I've replaced timing belt at 150911km and now on 210911 the warning light come on again, exactly 60000 km.
Can it be that when I reset the light I made a mistake or do I need to replace again. Is ther a sencor on the belt?
Timing Belt
- Town: Kyalami
- Real Name: Mike
Re: Timing Belt
It sounds like you reset it incorrectly, there is no sensor on the belt, its replaced on distance
- Real Name: Marnus
Re: Timing Belt
Stel weer die liggie in maak seker dat die waarde wat jy insit 9 is. Dan sal die liggie oor 90 000 km aankom. Kyk heel onder aan hierdie draad hoe om die verstelling te maak as jy nie seker is nie. https://www.hilux4x4.co.za/views/viewto ... =3&t=25132
