1996 Hilux Raider, Double Cab, 2.4 - Petrol , 22R Motor
Ivan Balk
Vehicle: Hilux 1996 4x4 Petrol
Real Name: Ivan
Post by Ivan Balk »
Hi
I've had over heating problems with my vehicle, have narrowed it down to the block is probably cracked. Looking for sub assembly or block in good condition. Can anyone help or give advice? Thanks Ivan
Re: 1996 Hilux Raider, Double Cab, 2.4 - Petrol , 22R Motor
It's very uncommon to have a cracked block on a 22R unless it's been subjected to thermal shock (filling cold water when the motor is hot).
What makes you think it's the block?
Ivan Balk
Real Name: Ivan
Post by Ivan Balk »
Hi there
Thank you for response. Do you know if there is any other way to check if there is a crack without stripping the whole motor? Do you perhaps have a contact number that I can contact you on? Thank you Ivan
Tim86
Real Name: Tim
Post by Tim86 »
What other possibilities have you eliminated and how have you done so?
Where do you suspect the crack to be - internal or in the external water jacket?
Ivan Balk wrote: Wed Mar 13, 2019 3:40 pm Hi there
I'll send you a PM. :winkx:
