Diff lock on IFS is this possable????
- Vehicle: 3 d4d Fortuner
- Real Name: Henry
Hi all
I have heard people talk about diff locks on IFS 4x4's. Has anyone got a photo of how it looks like and works? If I'm correct ain't the front CV joints? :?
In the new SA 4X4 magazine they spoke about this front diff lock, is there such a thing or am I losing it?
H
H
Re: Diff lock on IFS is this possable????
The fact that it is not not solid beam axle does not exclude it from being possible to use a difflock on. I have a difflock in my Pajero in the rear and it is also an independent axle with CV joints.
But I am not sure what options you have for buying a locker
- Town: Kathu
- Vehicle: 2.4 Hi Lux 4x4 DC 95'
- Real Name: Eben
- Club VHF Licence: ZS3EP
It is not the suspension that allows a diff lock. If a vehicle is 4x4 there will be a diff in the front and should you have a diff lock option in front it will lock the diff spiral gears. It doen not matter if it is a SFA or IFS.
Eben Pienaar
2.4 Hi Lux 22R 95'
2.4 Hi Lux 22R 95'
- Real Name: Henry
Ok
What would diff locks for CV joints go for?
H
H
I think you are confused. The diff-lock is a device installed inside the pumpkin of your diff. If you look at your rear axle you will see there is that round thing with the two pipes extending to the wheels. Now inside that round thing is your diff or differential. The diff is the device that will compensate for the different speeds your wheels turn when going around a corner. If you go round a corner your inner wheel will turn slower than your outer wheel. The diff must compensate for that otherwise you will have a hard time turning.
If you crawl underneath your vehicle you will not that your front diff have the same pumpkin thing as the rear one. Weather you have an IFS or SFA hilux it does not matter, the pumpkin will still be there. The only difference is that with the SFA two solid pipes will extend from the pumpkin to your wheels. With the IFS it will only have a short piece of pipe and then the side shafts extend to the wheels. At the wheels you have a CV joint which is a constant velocity joint which enables the shaft to turn at an angle and still maintain a constant volicity.
So, the diff lock is inside the diff itself. Whether it is a IFS or not the diff lock sits inside the diff and have nothing to do with the CV joints.
The diff lock locks the diff so that the axle actually becomes a solid axle "without a diff". This will prevent one wheel from spinning while the other one stands still due to the differential action. This locks the diff so that both wheels receive the same amount of power.
The only reason why you might not get a diff lock for the IFS is because perhaps they did not manufacture one for that specific diff. But I am sure there will be one available. The story I heard is that the cheaper one is not available for the IFS Hilux but the more expensive models are available.
- Okkie Van Wyk
- Town: Middelburg
- Vehicle: 2011 Hilux 3.0 D4D D/C
- Real Name: Okkie
- Club VHF Licence: N019
Okay lets try and see if we can solve this issue
Firstly As Pieter mentioned the diff lock goes inside the diff itself. Whether it is a IFS or not, the diff lock sits inside the diff and have nothing to do with the CV joints although it locks the shafts together it is done inside the diff centre or the pumpkin of the diff
The CV joints are locked to the wheel with the free wheel hub locks and runs free when not locked “That’s when you lock the wheels for driving in 4X4 The CV joints are permanently connected to the diff on the inner side and are driven trough the diff by the prop shaft when 4X4 is selected
When a diff lock is fitted to a diff , in the case of the IFS it will be a ARB the internal parts of the diff are locked inside the diff centre and the left and right hand shaft is locked to become one shaft . This is also called a selectable locker as it can be selected on the driver’s request. This locker needs air to be engaged and disengaged and a compressor is there for also installed
The cost for a ARB diff locker installed with a compressor as this is not a job for the DIY man is quite pricy at +- R13 500 at LA-Sport and sadly as Pieter also mentioned there is no les costly option for the IFS
123 WEG MP
2011 Hilux Vigo 3.0 D4D D/C
VENI VICI VIDI
CAME, I SAW, I CONQUERED
VENI VICI VIDI
Here is some nice info to help you understand diffs and diff locks better
http://auto.howstuffworks.com/differential2.htm
http://auto.howstuffworks.com/differential6.htm
- Real Name: Henry
Hi confused
Maybe I asked the question wrongly.
In the new SA 4X4 Off road adventure mag, every month one reader can place there profile, vehicle specs and future modifications in the mag. This guy I'm talking about has a 4x4 '90 Isuzu 280 DT aka HULK( looks very nice by the way) but wants to put in a front diff-lock. :?
Now I have seen the 280dt's they don't have a solid diff in front, just CV's, so how can he install a front diff-lock. :? (A diff-lock locks the wheels so that they turn at the same speed am I right?) :?
Only solid-diffs can be installed with a diff-lock am I right? :? I've read that the Gelanderwagens can lock all 4 wheels so that they all rotate at the same time/speed what-ever. :D My vehicle is a Toy Hilux IFS 4x4 with a diff-lock can I install a front diff-lock?
In the NEW SOUTH AFRICA: Quote:They pull you down to there level and beat you with experience.
- Town: Kathu
- Real Name: Eben
Mr H
Maybe you are not reading the posts above to help with the confusion. As Piet petoors explained the front and rear diff is having that center part where the driving shaft is connected. This you will find on SFA and IFS diffs. So yes you can fit a diff lock to a IFS. Forget the fact about the CV joints it has nothing to do with the diff itself. Yes the diff locker locks the spiral gears inside the diff and both wheels will be turning the same speed and direction and yes there are some vehicles that do have front and rear diff locks as well a center transfer case lock. This will able the vehicle that the all 4 wheels turn the same speed and direction.
Eben Pienaar
2.4 Hi Lux 22R 95'
2.4 Hi Lux 22R 95'
- Riceburner
- Town: JHB
- Vehicle: D2 V8
- Real Name: Darryl
ARB or Lockrites/ezy/ are available for 7.5" front IFS diffs.
If you are still confused as to why CVs does not have anything to do with diff locks reads this article I wrote. If you then still do not understand, I give up
viewtopic.php?f=34&t=953
- Real Name: Henry
I see the light
Thanx I was staring blind at the CV joint factor thinking like ass!!
To all the reply s benhur, Riceburne, Knersus, Okkie Van Wyk ,pietpetoors , thanx for baring with me. If I ever meet you guys in person I'll stick you for a "stiff dop"!!
Mr H
Mr H
- Okkie Van Wyk
- Town: Middelburg
- Real Name: Okkie
So Mr H
Now that we'r friends tel us where u are from so we can take u up on that dop ........................HEHEHAHAHA
Hope u are sorted out now and if u need to ........just ask ,if we can we will hellp
123 WEG MP
VENI VICI VIDI
VENI VICI VIDI
- Real Name: Henry
Thanx Okkie
PRETORIA and it will always be Pretoria, to specific Wonderboom South.
When in P-town just say the magic word stiff-dop I'm true to my word!
By the looks/sound of it few people have diff-locks for IFS, to expensive? Well after you mentioned R13.500 I lost interest.
H
H
- Okkie Van Wyk
- Town: Middelburg
- Real Name: Okkie
Mr H
Ek sal veel eerder geld spandeer op n winch as die diff lock voor ,Jou bakkie het mos n diff-lock agter en die winch is goedkoper en kan vir baie dinge gebruik word. Sal net diff-lock in sit as ek nou regtig in 4X4 kompetiesies wil deelneem maar vir aledaagse gebruik is dit wat my bakkie het meer as genoeg .
Groetnis my volk
Okkie
Groetnis my volk
Okkie
123 WEG MP
VENI VICI VIDI
VENI VICI VIDI
