CURE FOR SQUEAKY CHASSIS
Toppie4x4
Vehicle: Hilux 4.0 V6 DC 4x4
Thu Jan 23, 2014 11:19 am
The normal squeaky culprits are the rear shock rubbers and leaf shackle rubbers.
I’ve found that lubricant is not that efficient without removing the moister first.
I am using Q20 to remove moister, apply and drive around the block over speed humps etc.
Then I am using Loctite multi spray, drive around the block and all squeaks gone.
It last until the next high pressure chassis cleaning. :thumbup:
Thabogrobler
Club VHF Licence: x223
Thu Jan 23, 2014 12:20 pm
Just take out the rubber bushes and pack with grease. Problem solved for years and years!
Hangover
Town: Deneysville
Real Name: Stef
Thu Jan 23, 2014 2:06 pm
Thabogrobler wrote:Just take out the rubber bushes and pack with grease. Problem solved for years and years!
I ou toppie by vaal spring works het my vertel dis die slegste ding wat jy kan doen met n bladveer... Die grease versamel sand en dit maak grinding paste. Maak vir my nogal sin...
Ek dink dis hoekom OME daai geel plastiek spacertjies gebruik op hulle leafs... Nogi rerig veel na ander bladvere gekyk nie...
m2cw
Hangover(A.K.A die speelding)
1976 FJ45 4x4
1UZ-FE 4.0vvti
2" OME Suspension lift
1.5" Shackle lift
35" Geo MT's
Custom Bullbar
Lockright Locked rear
York OBA
20" LED bar
Nighthawk 100W spots
Dakar
2013 3.0D-4D 4x4 Hilux Dakar
Return to “Useful Articles”
